Help with Yinxiang 170FMN 300cc
Hi I bought a yinxiang 170FMN and as most are probably aware customer service is none existence.
I know its a replica of a 1972 - 1996 honda cg125 question is are the valve settings the same.
you can get the honda service manual from carlsalter in there it states the valve is 0.08mm does anyone know if it is the same thanks.
Also there are 6 wires coming from the engine which are not from the stator would these be for a gear indicator???
Im currently building a custom bobber using this engine.
Once its finished im going to upload all pictures and diagrams etc i have used to get it to work as to help many of you on here who im sure have had problems ive documented the build quiet well so should be interesting to see from start to finish to help other novice builders
Thanks in advance for any help given hopefully i can return the favours.
Re: Help with Yinxiang 170FMN 300cc
About valve clearance - yes, 0.08 mm on both valves would do the job.
About six wires - you could remove left crankcase cover and check where those wires end.
