[250] Zongshen Wired Diagram
Hi!
I'm newbie here :P
I'm searching for wired diagram for my Zongshen (probably cb) 250cc engine cooled by water.
Here's picture of my engine:
http://ep.yimg.com/ay/yhst-905885882...ne-motor-3.gif
Image from this site: http://www.pccmotor.com/4st25zoohcwa.html
I found this wired diagram:
http://i216.photobucket.com/albums/c...ingdiagram.jpg
on this site:
but I don't know if it fits with (cb)250cc (it's for 250gs (motorbike) and there's no info about cooler for radiator, so I think, this is for air cooled engine).
Thanks in advance.
Re: [250] Zongshen Wired Diagram
ZS250GS is based on Yamaha. Yours is based on Honda CG125.
Wiring : Refer to those CG & clone
Thanks for your reply and help.
I found this site:
http://www.robocog.dyndns.org/cg125/electrics.php
Maybe it will be usefull for someone else.
Most vertical chonda are similar to:
http://do.ejdz.cn:8087/%E6%91%A9%E6%...F%E5%9B%BE.gif
What shape is on ur stock CDI ? 1 http://www.sanxin.com.cn/exhibit/upl...8522499844.jpg or 2 http://www.sanxin.com.cn/exhibit/upl...5371625487.jpg
Some shitty wire harness are made from CCA https://en.wikipedia.org/wiki/Copper...aluminium_wire. Pls buy from "good" shop ONLY.
How to check? Use lighter to burn it. CCA = white stuff (Al oxide) present after burning
Good day to all,
I owned a CPI DTR150 motorcycle or also known as sinnis trackstar in UK, obviously it's a chinese 150cc motorcycle, having problems with the turn signal and horn, it will only activate if I press the front brake lever and foot brake together, Tried tracing all the wires and found no breaks in the line or shorted wires, maybe some of you here have a wiring diagram of this motorcycle or any suggestions on how to troubleshoot the problem. I already search for the its wiring diagram but found nothing similar on the internet. http://www.hausmotors.com/motorcycles/sports-dtr-150/
CodeStepper,
Here is a link to the original (Not CSC) Zongshen RX-3 service manual. THis bike uses a 250cc water cooled motor. I'm not sure if it is the same as yours, but is worth a look. The wiring diagram is on page 78.
https://copy.com/7VCX0BtJitQgcz7w
Dan K.
a lot chinese speak english? You may find some atv parts at www.chinesemotopartsonline.com/atv-parts ,there have atv engine..
