Thanks Zorge,
Beniamin, did you bought this particular bike you took for a test ride, the red one, or simply another BN 251?
About oil filter: can importer/dealer provide you info about it's part number (or another specimen, so you can do some measuring and catalog "combing")?
I have make wit the test bike 900km, and there was no problems with.
The only thing i must make in my bike (i make since thursday 300km, drive in) is put a little rubber to keep distance from gauges to lamp. There is no distance between, and the gauges touch the lamp, making a liitle noise.
The fuel usage was 3,7liter pro 100km, agressive, fun drive. 3,5 liter on 200km trip + 200km little city traffic.
If you have any question please ask.
Zorge, the fun drive was on the test bike, which i break in. And make with 900km.
My engine has 300km...
The front brakes are a little spongy, maybe, but i thought they will be better after few hundreds km. If not i will change the brake pads.
There is a option to mount secound brake disc on the front wheel.
How many km you have made with?
Have you changed oil maybe? The importer of benelli send me a hiflo 131, with confirmation that it is the right filter. But on tabobao i see that the filter should have rubber on it, what hiflo do not have.
I made another reply on other thread earlier about the brake and some other issue. I was asking if you are ok with brake, mine was not good even after 1000km , feel like going to collide to rearend in a emergency, so I changed to this.
Attachment 19573
a whole package, but the right disk has smaller diameter, same to bn301. and also use its clamp and master cylinder. The result is only acceptable, but not ideal (it looks cool, but doesn't feel like it's a 4 piston clamp, more like normal 2 piston).
Attachment 19574
better oil line might help...
