Regal Raptor in CIMAmotor
Was held in Chongqing, the 8th international exhibition of Chinese motorcycle CIMAmotor, regal raptor was present.
In this link are the novelties of regal raptor, http://www.cimamotor.com/chs/onlines...20/index.shtml
The novelty is the new version of the model SPT 400 cc
http://img233.imageshack.us/img233/8623/img0688r.jpg
Greetings riders :clap::clap:
Re: Regal Raptor in CIMAmotor
Looks a little like...
http://photos.imageevent.com/mychina...gQiRock-08.jpg
Only with water cooling and alloy wheels? :confused1:
Motorcycle data SPT regal raptor 350 cc
the same technical characteristics cimamotor motorcycle, but with smaller engine capacity and different aspect
is the same, but different versions
Length×width×height mm 2125×840×1115
Wheelbase mm 1470
Fuel Tank capacity L 28±0.5
Kerb weight kg 160
Rated load kg 165
Max. speed km/h 145
Brake type(Front / Rear) Disc / Disc
Brake Operating(Front / Rear) Manual / Foot Brake
Wheel Rim(Front / Rear) Light alloy / Light alloy
Tyre size(Front / Rear) 100/90-18、130/80-17
Tyre pressure(Front / Rear) kPa 225/225
Engine Model No. DD262MP
Make Regal-Raptor
Identification / Type Double cylinder, 4 stroke, water-cooled
Manufacturer LiFeng Group Co.,Ltd
Bore × Stroke mm 62×53
Engine capacity cc 320
Compression Ratio 10.2 :1
Max. Power kW/(r/min) 17kw/8500rpm
Max. Torque N·m/(r/min) 22N.m/6500rpm
Mini. Idle Speed r/min 1500±100
Mini. Fuel Consumption g/(kW·h) 354
Fuel Type RQ-93
Lubrication Forced lubrication
Lubricant Type SAE 10W/40 API SG
Clutch Type Oil-bathing multi-plate clutch
Starting Electric start
Ignition ECU+CDI
Horn Type DC(direct current)
Injection Type EFI (or Carburetor)
Spark Plug CR7HSA
Radio Interference Suppression Screened + Impedance
Pollution Control Description Catalytic converter +EFI(or not)
Speedometer Type Magnetic inductive
Headlight Type One light, Sealed headlight
Rearview Mirror Type Rectangular
Transmission Ratio
Primary: 3.631 Terminal: 2.286 Successive transmission ratio:/
I^:2.846 Ⅱ^:1.777 Ⅲ^:1.333 Ⅳ^:1.083 Ⅴ^:0.913 Ⅵ^:/
http://www.regal-raptor.com/eng/uplo...2650987286.jpg
http://www.regal-raptor.com/eng/uplo...2651501866.jpg
I do not see the resemblance to Qingqi
this bike looks bigger
:thumbsup:
Well yes it is a bigger bike being a 350-400, but the styling is similar. All black, two 17" wheels. Large capacity tank with standard foot peg positions. Under seat exhaust, "sporty" one piece saddle. The original picture of the red motorcycle you posted the first time also has the high mounted front fender.
CrazyCarl
And a lower fender as well. It looks like they were trying to make a sumo type by adding the mx fender but forgot to remove the stock one.
Sorry Carl I've ridden both and they are extremely 'unsimilar'! If you had a photo of both together, it would be quite obvious, the camera makes a certain similarity, due to lack of dimensional 3D perspective.
