3 Attachment(s)
Help! SO Many Wires! Pulse Adrenaline Loom.
Hello,
I have a Pulse adrenaline engine I bought from somebody breaking a bike. I also have the wiring loom. I am going to install it into an off road buggy. I have worked out where most of the connections go between the CDI and the engine, coil etc, but there's a few things I can't work out. There are 2 connectors that have about 9 pins each in them what are they for on the bike? There is also something that's a bit beaten up but it looks like a back disc with a number of dots on it at the end of a cable. I have no idea what its purpose is. Also the loom has been cut from the bike so I don't have the ignition barrel etc, so I can't work out which wires were connected to that. If anybody can help with any of this I'd be very grateful.
Cheers
H
Attachment 18320Attachment 18321Attachment 18322
Re: Help! SO Many Wires! Pulse Adrenaline Loom.
humanbeing
As pdf
Thanks HB :thumbsup:
The black disc is the Gear position sensor that would have been behind the left engine cover of the bike.
Without this you will have no neutral light or gear indicator on the dash.
The first pic looks like the wiring connectors for the handlebar switches-starter, lights etc.
And one may be the dash/clocks connector.
RE8ELD0G
Thanks RE8ELD0G always good to get this stuff confirmed, gives me a chance of getting it to run :scooter:
