5 Attachment(s)
Re: 2010 DF250RTB StatorOiling and Adjusting The Chain
whats up guys. Hope all is well around you. Not around me. Had a small incident today. Bumped this guy in front of me, no damage to his car.. but I bent my forks in a bit. very noticeable. I rode her home, but they need to be fixed. Any suggestions as to where to get a new set. It is just the to rods that I guess are part of the shock system. They bent under the lower part of the tree. Both sides pretty evenly. Broke my heart man. All my fault. Thought the guy turned, was watching on coming traffic, saw a chance to go... but he never moved. Barely bumped him.Put me down. He had not a scratch on his car thankfully. I have bent forks. heartbroken man... just heartbroken. I need to fix this, but honestly am not real sure where to purchase anything for it. Been looking on ebay, and see a lot of older used forks and stuff. Just not sure which is the best fix. Hopefully you gurus can help me out. She has 25,560 miles on her, and I want her to go further. So my question is really, since the lower part of them ( the black painted parts ) seems to be fine, can I just replace the chrome rods? How do I measure them.. with the bike off the ground? Since they are metric, would the circumference be the for all bikes? Like to fit inside the lower painted parts. Sorry my terminology is so off.. I hope you can understand me. I see kits here and there for Hondas and Yamahas and such, but not sure which would work.
Attachment 19268Attachment 19269Attachment 19270
You bent the stanchions. There maybe parts on Taobao, aliexpress, or banggood. Possibly entire front ends. You may need springs and damper rods as well.
Very cool I will check them out. Thanks for the correct name of the parts as well.
So I gather that these are all standard sizes and will just fit? Or do I need specific diameters?
I figure on just replacing the stanchions. So I know the lower end still works for the caliper
You're welcome.
You will need to know the diameter of the fork stanchions. They are more than likely 33mm, but double check. You may also need the length of them as well. That will require the forks to be disassembled. It may not be possible to disassemble them if the damper rods are below the bend in the stanchions.
is the measurement of 33mm outside or inside? just double checking.
humanbeing
Thats pretty wild. I do not have a set up like that, but good to know.
bowtiewagon
Outside
google "straightening bent fork tubes" to get an idea how you might starighten them. Some say a machine shop can straighten the tubes.
Another maybe crazy idea since it seems both tubes appear to be bent the same. Loogen the triple tree bolts and rotate the tubes so the bend is to the front. You would get more rake. Maybe too crazy.
I read where the tubes are 41mm. I can measure mine in the morning.
