ya with both bulbs out, front an back I'm sure its just a ground or loose connection somewhere
check em out and order up
http://www.ccwthariders.com/shop.html
well fixed my taillight issue, ended up being the brown wire coming off the little bulb inside the headlight housing, it was just wiggling around in the bullet connection
hey gardo i read in a post that you ran a different size sprocket but you never mentioned what size
also do you have a link for the sprocket you bought
also do you know what size rear axle the heist has
thanks
I am running a modified head/carb/ and custom pipe so my bike is kicking double the HP of a stock Heist, my gearing will bog out the stock bike.
With that being said i am running a 16T front and a 38T rear with a 428DID chain
On the Stock bike you can run the 16T front sprocket and 428DID chain and the bike will feel great. You can order them from www.weaverrides.com or just email Kelly: kelly@weaverrides.com or call 609.444.8262
they keep them in stock with all the gearing.
For the full parts list and manuals on the Heist and Misfit go here
hope that helps
~Gardo
Here is a fairly recent pic of the bike, still some things to finish here and there but about 95 percent done.
Attachment 7260
thanks Gardo, i got everything except the mod head, what size rear sprocket is stock?
do i need a whole new chain for the new sprocket, I only have about 300 miles on the bike
isn't the stock chain a 428 ?
manual says axle size is 15x275.....whats that ?
its in MM 15mm by 275mm equates to roughly bigger than a half inch by just under 11 inches
the stock chain is a 428STD, i would ditch it. the stock chain I found needed constant attention so it had to go.
the stock sprockets are 15T front and 41T rear, if you already have the did chain you are good
