Lexemoto adrenaline electrics dying
Hi there wondering if people can help me here I have a pulse adrenaline 15 plate i am having issues with it at the moment sometimes the electrics just dye other time it's fine when the electrics dye it's saying the battery is flat but even when it wants to work the battery says it's still flat i have no ignition no headlights any ideas please want to get this sorted asap
Thanks Jamie
Re: Lexemoto adrenaline electrics dying
Hi there thank you for sending the links but I have changed the fuse to a new one 2days ago and still the same issues but what I am saying is there are no electrics at all when it dies so the bike won't even turn over what else do you think it could possibly be ?
Thanks Jamie
And also there are times when I'm riding it and it wil just die electrics everything fail and then it will decide to come back on after bumping it 10 times but once bumped still no proper power but can't understand why it would completely cut out the engine and all electrics while riding it and then it just conks out
This suzuki family depends on reliable DC supply...
Stock sealed battery are known for short life... http://www.chinariders.net/showthread.php?t=9238 1. Natural cause: Poor workmanship... 2. Bad r/r = overvolt boiled it dry ...
BAD battery holds nothing when stressed, so there's capacitor trick (generator & r/r in working order NEED!!!)
Chance of this http://translate.google.com/translat...082&edit-text= is rare...
Wd40 down the ignition barrel and turn the key a few times then repeat again for good measure. Make it part of your maintence ritual.
