Re: Parts for 2008 XF 200 Qlink nowhere to be found???
MJH
Thanks for the info!!!!
MJH
ok thanks
MJH
It is taobao and if you are not up for a challenge, forget it. it’s a virtual market place in Chinese, it helps when you use Google chrome with a built in translator. But only helps bad translations make it also confusing as well. The translations do not always make sense.
If you have downloaded Google Chrome then once you are at
taobao you then search on the factory name of the motorcycle QM200GY-B, just type that in the search box, then you get parts for it.
This is a link for a clutch basket
http://item.taobao.com/item.htm?spm=...id=35380345465
Once you locate a part you want then you copy the URL as it is like above, that is what is in the browser command line as in
http://item.taobao.com/item with what ever the link to the item is. You then can order it through a service with that item link, a service that will order it for you like this one
http://taobaofocus.com/
You could also pay for ridiculous shipping and order parts from the UK.
They are called Sinnis and Pulse there, they are all 125cc there but many parts are the same, except the engine and related.
http://www.chinesemotorcyclepartsonline.co.uk/
There are lots of parts on Taobao for the bike and are crazy cheap, the freight is not though but add it up and its still cheap.
Wow sounds like a lot of work. I will give it a try. Thanks
What parts are you searching for?
Whygostock
Top end parts Piston, valve etc.
Have you checked with SSR or Qlink?
Whygostock
yes I have checked with both. no one responds.
You could pull up the parts diagram, its on this site as a download.
Then compare it to a diagram of a DR200 engine and see if they are compatible.
http://www.bikebandit.com/1988-suzuk...9439#sch237641
Let me know exactly which parts you need an I will work on it.
