Maybe it's just being left out since it's kind of redundant saying that a motorcycle engine is for motorcycle use.
So you need to have under 7th character always M… but optional
163FML Forced air for F and L is 200cc ( M is used)
Then 170MM where M is water cooled and M is 250cc, but M is not their as above? ( M is not used)
The use of M consistently in the 7th character place is or could be an older convention, the later engines do not adhere to it.
I read it again unsigned is water cooled, sorry about that so the M still represent Motorcycle, so in cases were there are only two characters alpha(after the cylinder and bore) then it is water cooled.
So then....if in a computer program the code would have to insert a null character where the Chinese should have placed a "W", other wise it would not read the characters consistently.
should be YG170 MM
should be YG163FML
Ok I added that in.
I'd like make a form that could decypher all this automatically but I've totally forgot how to program :(
does not matter we can do it manually in our noggins.
Hi I just got mini chopper and can't figure out what kind of motor it is. Serial number is.. 139FMB*041200028* If anyone knows what cc motor an whether it takes regular gas or with 2-cycle or disel fuel. Help plz
1 - One cylinder
3 - 39mm bore diamater
9
F - Air colled
M - For motorcycle use
B - 50cc
A quick Google confirms this and that it's also a 4 stroke. There are 3 varients of this engine shown here.
http://www.china-parts.co.uk/acatalog/New_Engines.html
Hello: I've acquired a number of engines but cannot decipher who made them or what they are. Can anybody help? The numbers are:
TZH152FMH 60607091
IP54FM1 51214377
LC1P391MA DC009900
LC152FMI FZ132484
152FMH 08064827
It's possible that some with a prefix of 1 could be I or vice versa. Any assistance would be appreciated.
TZH - Series or manufacturer
1 - single cylinder
52 - 52mm bore diamater
F - Air cooled
M - for motorcycle use
H - 110cc
IP - Series or manufacturer
54 - 54mm bore diamater
F - air cooled
1 - Unknown (if it's an I it's a 125cc)
LC - Series or manufacturer
1 - single cylinder
P - Horizontal bore
39 - 39mm bore diamater
1 - unknown, could be part of the bore diamater number meaning that it's 39.1mm
A - less than 50cc
1 - single cylinder
F - air cooled
I - 125cc
1 - single cylinder
F - air cooled
H - 110cc
Thanks very much for your reply: Do you have any idea of which manufacturers use the prefixes, "TZH", "IP" and "LC"?
