maybe http://item.taobao.com/item.htm?id=4283525082
or same 3.50 http://item.taobao.com/item.htm?id=10421193842
http://item.taobao.com/item.htm?id=10868030700
Thanks a million, Jape - truly appreciate it. I've been having a tough time finding this stuff.
Last challenge: find a dealer that pays me to acquire and use it.
can i get a translation for:
sit on my face and tell me that you love me, i'll sit on your face and tell you i love you.
its very important for when i get pulled over by the police, i will say i understand a little chinese, they will ask me for my license and then i say that... i dont think they will bother asking for my license again.
With tone marks, and many thanks to Sheng Jie!
Motorcycle Parts Names in Mandarin
摩托车词汇大百科 英汉对照(简体修正版)
This version is modified by Sheng Jie, from Taiyuan, Shanxi
欢迎大家积极学习交流!:)
Parts
adapter 转接座 zhuǎn jīe zuó
air box 空气滤清器盒 kōng qì lǜ qīng qì hé
air filter 空气滤清器 kōng qì lǜ qīng qì
alternator 交流发电机 jiāo líu fā diàn jī
aluminum 铝 lǚ
aluminum rim 铝框 lǚ kuāng
axle 车轮轴心 chē lún zhòu xīn
battery 电瓶 diàn píng (motorcycle/car)/ 电池 dìan chí (electronics)
bearing 陪林 péi lín
bike stand 主车架 zhǔ chē jià (center stand)
bolt 螺栓 luó shuān (refers to the bolts on the wheel)
bracket 束环 shù huán
brake 刹车 shā chē
brake caliper 卡钳 kǎ qián
brake light 刹车灯 shā—chē—dēng
brake line 刹车油管 shā—chē—yòu—guǎn
brake pads 刹车皮 shā chē pí
brake rotor 刹车碟盘 shā chē díe pán
bulb 灯泡 dēng—pào
cam shaft 凸轮轴 tū lún zhòu
carburetor 化油器 huà yòu qì
carburetor jets 油嘴 yòu zuǐ
chain 链条 liàn tiáo
choke 阻风门 zǔ—fēng—mén
clutch 离合器 lí hé qì
clutch cable 离合器线 lí hé qì xìan
clutch pads 离合器片 lí hé qì pìan
coil 高压线圈 gāo—yā—xiàn—quān
connecting rod 曲轴柄 qū zhòu bǐng
coolant 冷却剂 lěng—què—jì
crank shaft 曲轴 qū zhòu
cylinder 汽缸 qì—gāng
drum brakes 鼓刹 gǔ shā (鼓式刹车) gǔ shì shā chē
disk 碟盘 díe pán
electrical tape 电器胶带 diàn qì jiāo dài
engine case 引擎外盖 yǐn—qíng—wài—gài
engine head 汽缸头 qì—gāng—tòu
exhaust pipe 排气管 pái—qì—guǎn
fairings 整流罩 zhěng—líu—zhào
front fork 前叉 qián chā
fiberglass 玻璃纤维 bō—li—xiān—weí
filter 过滤器 gùo lǜ qì
foot pegs 脚踏杆 jiǎo—tà—gǎn
frame 车台 chē tái
fuel gauge 汽油表 qì—yòu—biǎo
fuel injection 燃油喷射 rán—yòu—pēn—shè
fuse 保险丝 bǎo—xiǎn—sī
gas cap 油箱盖 yòu—xiāng—gài
gas line 油管 yòu—guǎn
gas tank 油箱 yòu—xiāng
gasket 垫片 diàn piàn
gauge 表 biǎo
gear 档 dǎng
gear lever 脚踏变速杆 jiǎo—tà—biàn—sù—gǎn
generator 发电机 fā diàn jī
grease 黄油 huáng yòu
handle bars 车把手 chē bǎ shǒu
handle grips 手把套 shǒu—bǎ—tào
head light 前灯 qián—dēng/ 头灯 tòu—dēng
horn 喇叭 lǎ bā
horn button 喇叭按钮 lǎ—bā—àn—nǐu
hose 水管 shǔ—guǎn
ignition 开关 kāi—guān
ignition button 开关按钮 kāi—guān—àn—nǐu
intake 气管 qì—guǎn
jet 喷嘴 pēn—zǔ
key 钥匙 yào—shi
kickstand/side stand 支架 zhī jià
kickstarter 脚踏发动杆 jiǎo—tà—fā—dóng—gǎn
levers 拉杆 lā—gǎn
license plate 车牌 chē pái
linkage 打档杆 dà—dǎng—gǎn
lock 琐 suǒ
magnesium rim 镁框 meǐ—kuāng
master cylinder 总泵 zǒng—bèng
metal 金属 jīn—shǔ
mirror 后视镜 hóu shì jìng
muffler消音器 xiāo—yīng—qì/灭音器 mìe—yīn—qì
neutral light 空挡灯 kōng—dǎng—dēng
nut 螺丝帽 luò sī mào
odometer 里程表 lǐ—chéng—biǎo
oil 机油 jī yòu
oil additive 添加剂 tiān jiā jì
oil filter 滤油器 lǜ yòu qì/机油过滤器 jī yòu gùo lǜ qì
oil gauge 机油表 jī—yòu biǎo
oil pan 油底盘 yòu dǐ pán
oil pump 机油泵 jī yòu bèng
oil seal 油封 yòu—fēng
oil: blended synthetic -- 半合成机油 bàn hé chéng jī yòu
oil: petroleum-based – 矿物油 kuàng—wù—yòu
oil: synthetic 合成机油hé chéng jī yòu/人造油 rén zào yòu
pet cock 油箱开关 yòu—xiāng—kāi—guān
piston 活塞 huò —sāi
piston rings 活塞环 huò —sāi —huán
plastic 塑胶 sù —jiāo
pulley 普力盘 pǔ lì pán
pulley belt 传动皮带 chuán dóng pí dài
pully rollers 普力珠 pǔ lì zhū
pump 帮浦 bāng—pǔ
radiator 水箱 shuǐ—xiāng
radiator cap 水箱盖 shuǐ—xiāng—gài
reservoir 副水箱fù—shuǐ—xiāng
rim 轮框 lún kuāng
RPM gauge 转速表 zhuàn sù biǎo
rubber 橡胶 xiàng jiāo
seal 油封 yòu fēng
seat 坐垫 zuó diàn
shell/fairing 外壳 wài ké
shocks 避震器 bì zhèn qì
slicks 光头胎 guāng tòu tāi
spark plug 火星塞 huǒ xīng sāi
spark plug cap 火星塞盖 huǒ xīng sāi gài
spark plug wire 火星塞传导线 huǒ xīng sāi chuán dǎo xiàn
speedometer 速度表 sù dù biǎo
spoke wheels 钢丝框 gāng sī kuāng
spring 弹簧 tán huáng
sprocket 齿盘 chǐ pán
starter motor/motor 发动机 fā dóng jī/ 起动机 qǐ dóng jī
stator 发电机飞轮 fā diàn jī feī lún
steering damper 防甩头 fáng shuǎi tòu
swing arm 摇臂 yáo bì
tail light 尾灯 wěi dēng
tail pipe 尾管 wěi guǎn
temperature gauge 温度表 wēn dù biǎo
thermostat 水龟 shuǐ guī
throttle 油门 yòu mén
throttle cable 油线 yòu xiàn
throttle controller 油门座 yòu mén zuó
tire 轮胎 lún tāi
transmission gear 变速齿轮 biàn sù chǐ lún
transmission lube 传动油 chuán dóng yòu
transmission 变速箱 biàn sù xiāng
triple tree 三角台 sān jiǎo tāi
turbo 涡轮 wō lún
turn signal 转向灯 zhuǎn xiàng dēng/方向灯 fāng xiàng dēng
valve 汽门 qì mén
valve stem 轮胎气嘴 lún tāi qì zuǐ
water pump 水泵 shuǐ bèng
washer 垫圈 diàn quān/垫片 diàn piàn
windscreen 挡风板 dǎng fēng bǎn
windscreen(glass) 挡风玻璃 dǎng fēng bō li
wiring harness 电线总成 diàn xiàn zǒng chéng
voltage regulator 电压调整器 diàn yā tiáo zhěng qì
zip tie 束带 shù dài
Terms
1st gear 一挡 yī dǎng
2nd gear 二挡 èr dǎng
3rd gear 三挡 sān dǎng
4th gear 四挡 sì dǎng
5th gear 五挡 wǔ dǎng
6th gear 六挡 lìu dǎng
2-stroke 二行程 èr xíng chéng
4-stroke 四行程 sì xíng chéng
acceleration 加速 jiā sù
adjust 调整 tiáo zhěng
burnout 烧胎 shāo tāi
change 换 huàn
change gears 换档 huàn dǎng
check 检查 jiǎn chá
compression 压缩 yā suō
crash (to have an accident) 车祸 chē huó
crash (to hit something) 撞倒 zhuàng dǎo
crash (to fall down) 跌倒 dīe dǎo
crash (to slide out) 滑倒 huá dǎo/ 甩倒 shuǎi dǎo
displacement 排气量 pái qì liàng
downshift 退档 tuì dǎng
drift 甩尾 shuǎi wěi
estimate (price) 估价 gū jià
fixed 修好了 xīu hǎo le
horse power 马力 mǎ lì
idle 空转 kōng zhuàn
inflate 打气 dǎ qì
install 安装 ān zhuāng
insurance 保险 bǎo xiǎn
license 驾照 jià zhào
leak 漏 lóu
lean (body) 侧挂 cè guà
lean (motorcycle) 压车 yà chē
loose 松 sōng
maximum speed 尾速 wěi sù
modify (stronger) 改装 gǎi zhuāng
paint 油漆 yòu qī
spray paint 喷漆 pēn qì
stock 原产 yuán chǎn
take off 拿掉 ná diào
registration 行照 xíng zhào
RPM 转速 zhuàn sù
soft 软 ruǎn
stable 稳定 wěn dìng
start (engine) 发动 fā dóng/启动 qǐ dóng
stiff 硬 yìng
tight 紧 jǐn
torque 扭力 nǐu lì
tune up 调节 tiáo jíe
wheelie 托孤轮 tuō gū lún
Riding Gear
boots 靴子 xuē zi
gloves 手套 shǒu tào
helmet 头盔tòu kuī/安全帽 ān quán mào
knee pads 护膝 hù xī
knee pucks/sliders 滑行块 huá xíng kuài
rain gear 雨衣 yǔ yī
riding gear (general) 防摔衣 fáng shuāi yī
suit (leather) 皮衣 pí yī
Brands
harley davidson 哈雷戴维森 hā leí dài wéi sēn(美国)
bmw 宝马 bǎo mǎ(德国)
yamaha 雅马哈 yǎ mǎ hā(日本)
benelli 贝纳利 bèi nà lì (意大利)
Triumph 凯旋 kǎi xuán (英国)
honda 本田 běn tián (日本)
aprilia 阿普利亚 ā pǔ lì yà (意大利)
ducati 杜卡迪 dù kǎ dí (意大利)
piaggio 比亚乔 bǐ yà qiáo (比亚乔)
moto guzzi 摩托古兹 mò tuō gǔ zī(德国)
bimota 比魔塔 bǐ mò tǎ(意大利)
KTM (奥地利)
kawasaki 川崎 chuān qí (日本)
suzuki 铃木 líng mù (日本)
sym 三阳 sān yáng (Taiwanese brand)
hartford 哈特佛 hā tè fò (Taiwanese brand)
kymco 光阳 guāng yáng (Taiwanese brand)
Types of Vehicles
Car 汽车 qì chē
Big Motorcycle 重型摩托车 zhōng xíng mò tuō chē
Motorcycle(general) 摩托车 mò tuō chē/机车 jī chē
Motorcycle(scooter) 摩托车 mò tuō chē
Motorcycle(gear shifting) 打挡车 dǎ dǎng chē
Motocross 越野车 yuè yě chē
Scooter 踏板车tà bǎn chē/速克达 sǔ kè dá
Supermoto 滑胎车 huá tāi chē
欢迎大家积极学习交流!:)
throttle body - 节气门体 - jié qì mén tǐ
Crash pad anyone?
MOTORCYCLIST=SHENG JING BING.
Gear shift drum?
Sent from my Nexus 5 using Tapatalk
Brands is missing name if Chinese bikes brands
