Pulse adrenaline air filter help
So I have a 2011 pulse adrenaline 125 and it's bog standard, decided to fit k&n style air filter to it, just slots onto the carb but now I have two rubber hoses and I don't know what to do, one of them is from the EGR valve (I think) and the other one is what I believe to be a breather from the crank case/gear case right under the air box, they both went into the air box and now I'm unsure what to do with these two hoses, I don't want to have EGR just for that bit more of performance boost and what I think is a breather I don't know what to do with, I'll upload pictures later on, I don't know whether just to put a bung in the end of each hose as they are both pushing air out, I don't want them to build up too much pressure and force the bung out, i would just like for people to help me confirm what these pipes are and if they are important or not and what I can do about them, all help is appreciated, and if you reply check back later as there will be pictures of it either on the main post or comments.
Re: Pulse adrenaline air filter help
Personally I've just left them hanging. For the breather you can get a small cone filter like the K&N style one that you have.
My EGR valve has been removed on my Lexmoto adrenaline, blocked the hoses off that was left
