Re: 150cc kit piston rings.
I don't think that you can simply bore out your bike's cylinder and fit suitable 62 mm piston - IMO, sleeve's wall to thin.
Zorge
Hi, I don't need to bore it. I have fitted a 150cc kit already but need to replace the cylinder rings and don't want to wait for some to arrive from China. I was wondering if the 62mm rings from a cg150 would fit as it also has a 62mm piston
A-ha, just rings!
Beats me.
I couldn't provide you reliable info, but if I would be in your shoes, I would find out (using Web or vernier/micrometer) what are the piston ring dimensions (not only diameter, of course) for both engines, yours and those on the CG clone. If they are the same, they will fit. If not... as Axl said, you "gotta have some patience". Simple as that.
http://www.dongya.cn/prodlist.asp?page=7&tp=4&keywords= CG150 62mm [1.2/1.2/2.5] is most common BUT there's other combnation. I would say MESAURE it 1st & ask the seller what's the spec of their rings...
HiGHER grade rings http://www.dongya.cn/prodlist.asp?page=2&tp=6&keywords=
