rear shock mistery
well, the rear shock of the QM200 have spherical bearings / bushings in both eyelets, and according ti the parts manual the spherical bearings apear as GEG12E, but the bolts apear as m10;
i asume that the bearing code has an error because it has an 12mm inner diameter, not compatible with the bolt.
someone have measures of it?
the bearing uses a inner sleeve?
in my bike both bearings have noticeable play (the suspension makes a clonck noise at times) but i dont want to tear apart the suspension because cant loose my daily transport.
http://www.contactdi.com/2009/qm/QM0092.jpg
Re: rear shock mistery
mistery solved:
the bearings, labeled #6 in the photo, arent GEG12E, and arent standard spherical bearings, but can be obtained with the distributor as spare parts.
tech. specs: spherical bearings, 10x24x14.5 mm.
take out the circlips (#5) and press out the old ones, then press in the new ones and install the circlips.
http://www.telecable.es/personales/a...suspension.jpg
Hi acif, great for coming back and let us know :thumbsup:
