Giantco City hunter 125 156fmi engine valve clearance
I recently rebuilt my engine replacing my barrel and piston but now the bike is refusing to tick over , i used the honda cg haynes manuel to get the valve clearance of 0.08 - 0.08 im not sure if this right does anyone know the valve clearances for the 156fmi engine ? would be verry apreshated as ive looked everywere and no one has it not in any forums or anywere :/
Re: Giantco City hunter 125 156fmi engine valve clearance
After searching google, it uses CG alike pushrod machine. 0.08 in / ex IS right .
What's the compression reading ??
I didnt use a torq wrench because i dont own one :/ , last night i was looking on google to see what the problam might be and some say the carb jet being blocked , so i took off the carb and amediatly noticed that i hadnt put the rubber gasket for the carb back on so i replaced it and cleaned out my float chamber whilst there , started the bike and it ticked over perfectly , but when i rode it today it wasnt ticking over hot or cold , im about 80% sure that i dont the valve clearance on the right stroke at tdc but if i didnt would this cause the bike to not tick over ?
