Apollo orion rx 125 supermoto
Hi guys, first post on this site havent found any others helpful at all. I swapped my lexmoto street for a apollo orion rx 125 now i have noticed theres alot of things up with this after getting familiar with it thati didnt spot at the time of having a look, the shock is awfully spongy they are adjustable what do i use to undo the adjuster?
The engine feels like its falling apart a horrible vibrating/grinding when accelerating and slowing down seems to be there pretty much all the time, not so bad at low revs its copable then and when clutch lever is pulled in so i guessed its either gear cogs chewed up or clutch but more to the gearbox problem,
I have a cg 125 that i can use as a donor for the engine etc as was told a lot of parts will fit, the engine so clocks say has done >40,000miles so may be worth putting new piston rings in will the cg engine fit straight in? i think shineray/zongshen ones would also
My other concern is parts where can i get them from in UK?
I had a pulse adrenaline 57 plate first model i think and other than wiring problems ect that seemed feel alot better made and although the apollo has 3600 miles/km on clocks its not nice to ride at all
Re: Apollo orion rx 125 supermoto
Medicinal_motocross
...>40,000miles so may be worth putting new piston rings in will the cg engine fit straight in? i think shineray/zongshen ones would also
That cg is from which yr? The latest model are using thinner ring... [1.2/1.2/2.5] is the standard one http://www.dongya.cn/prodlist.asp?page=5&tp=4&keywords=|http://www.mychinamoto.com/forums/sh...ll=1#post73089
Worst case u need REBORE by shop OR new barrel kit : http://item.taobao.com/item.htm?id=35543200934 | Good 'o Honda = XF125 (small fin) which unlike ZJ125 (large fin) http://www.motorfans.com.cn/bbs/view...originator=yes #2 1st pic. ZJ125 barrel (commonest chinese CG) can putted in Honda bike BUT don't looks RIGHT !!!
The cg is 1994 states on logbook CG125BR-K?
I dont mind it looking silly just bothered about reliability and it actually lasting,
any ideas for parts in the UK anyone? thanks
humanbeing
Fleabay had TONS of it. Most "chinese" from there are unmarked OR on shop's logo ONLY (unlike that page i linked in #2 that sates which is which...), Most quality are OK BUT there's a thread on http://www.bikechatforums.com/ saying the piston out of round ...
The minority http://www.ebay.co.uk/itm/331430791233 Pic showed rings made by a reputable brand.
BR-K =12v & points http://www.dansmc.com/bat_coil_ign.htm . Hopefully the electrics are still in working order , otherwise = PITA.
CG125A to CDI : https://translate.google.com/transla...93561-1-1.html
My guess is most any 125cc engine would work, provided they are plentiful and low enough cost (vs. playing around with the one on the bike) in the UK.
