Re: Pulse Adrenaline 150 big bore Kit
Luis Carlos
...unfortunately I can not translate what is written in the image...
"Draw" it in http://www.nciku.com
Diffeence btw 5 & 6: http://www.motoyes.net/bbs/viewthrea...&extra=&page=3
There's also other seller in taobao.com | Their photo showed Suzuki part # | GN125 used had 6-speed in some model BUT parts costs much MORE in west...
24260-***** Gear, 6th Drive
24361-***** Gear, 6th Driven
25310-***** Cam, Gear shifing
:lol8:http://forum.jorsindo.com/thread-2186287-3-3.html
#72 Too much spare time ... Mod everyday
Ans: Time is like cleavage, squeeze & u will get some
Hi
Humanbeing thank you for your help!
the nciku.com is a very usefull tool!
Sorry for my ignorance, but to change to 6 speed, we have only to add a sprocket in the gear box? I already tried to use google chrome translation to understand the links in chinese, but I didn't understand what it's needed to make the change from 5 to 6 speed.
If it is a simple modification, maybe I'll try to make it.
I think that my bike with 6 speed will improve a lot.
Thank you
Most importat/ difficulties in this mod = "Q&A" : #43 & #45 in above "motoyes" link
Study HARD the DR125/ RV125 (NOT the early 2 stroke / It's 2003 onwards) service/ parts manual -How to assembly 4 these "6" machine IF u don't get the idea from above link (#41 = Driven #42= Drive) :naughty:
Have you run the 150 kit in yet? how is it? did you need to adjust the mix or change jets? what exhaust did you use? thanks
Hi
Yes I already have the 150cc kit in it!
I think the bike now have more power, now most of the time I use the 5th gear. I want to change the sprocket,because I want a little more top speed.
I changed the jets, now I have #105 main jet, but I want to try a bigger one, #110 or #115!
150 big bore kit is worth every penny.
Superfamous, this website can help you calculate tooth of sprockets. http://www.gearingcommander.com/. Mine increase 10% top end speed.
Sorry about posting in an old thread but does anyone have any idea on what postage I can expect to pay when I order my big bore kit from taobao; I don't want any nasty supprises.
It's 2-2.5kg depends who packs it.
You can checks this "frowarder" http://www.sendfromchina.com/ that many fleabay seller are using for int'l rate. Compare taobao "agent"s... int'l rate b4 place the "order".
The "kit" is from Shandong that uses http://www.ems.com.cn/mainservice/em...i_kuai_di.html. Most agent are Guangdong based (1,8??km away). If the Shanghai based (8?? km) agent's Int'l rate is suitable, order with them to save time.
Thanks for that, so I'm looking at about £30 for delivery then. I'll probably wait until I get some more cash together then.
superfamous
Hi
I just mount a 1500cc big bore kit in my pulse adrenaline
there is some photos.
How did your piston rings seat as I any get mine started after fitting bite bore kit timing is perfect and sounds like it trying to start off a bump but won’t go
