Re: CFMOTO 650nk gremlins
Mine flashes on start-up because it's asking for a service but the usual code clearing doesn't work on my bike for some reason. If the bike runs OK I'd just put some gaffa tape over the flashing light!
Just a quick update, ecu has been checked fine, turns out I was reading the codes wrong, error 11 is 1 and error 16 is 6. Found I had left the air sensor disconnected by mistake when putting the air box back in and that error cleared. The error 1 low tps has been found to be caused by a incorrectly calibrated replacement tps. The previous owner has removed the LAMS restriction throttle stop block and in the process it cracked the mount off the side of the throttle body, that mount is also used as a stop for the return Spring for the throttle and to hold tension on the return Spring for the throttle body. When bike shop calibrated the tps the initial 0 position was really partially opened throttle so when wound back by hand instead of 0 position it was going negative and bringing up low tps. Bike shop guy calibrated tps by manually moving the position from holding fully closed to full open then throttle linkage at the throttle bodies and all is good. I've made a temp bracket for the return Spring to hold tension and works a treat until my new throttle body setup turns up.. Hope this fixes this bike once and for all......
