Que envidia me das!
Que envidia me das!
Does anybody know the meaning of 15 fast blinks on the EFI light? It just happens when I turn the key, after that it goes off. There are no other symptoms.
These are the error codes from the handbook 31 codes numbering up to 52. Therefore there must be some unpublished codes. Most likely it is just a 'get your bike serviced' code. You could ask a dealer, but in China they probably don't have a clue. Your best chances are emailing the factory. You can try doing the reset, but doesn't work on my bike, dunno why.
ERROR TYPE ERROR CODE FLASHING TIMES
ERROR_TPS(Throttle Position Sensor)_LOW 1 1(S.F.)
ERROR_TPS(Throttle Position Sensor)_HIGH 2 2(S.F.)
ERROR_TH O (Water Temp. Sensor )_LOW 3 3(S.F.)
ERROR_TH O (Water Temp. Sensor) _HIGH 4 4(S.F.)
ERROR_TA IR (Air temp. Sensor)_LOW 5 5(S.F.)
ERROR_TA IR (Air temp. Sensor)_HIGH 6 6(S.F.)
ERROR_ PA IR (Air Pressure Sensor)_LOW 7 7(S.F.)
ERROR_ PA IR(Air Pressure Sensor)_HIGH 8 8(S.F.)
ERROR_VB(Battery Voltage)_LOW 9 9(S.F.)
ERROR_ INJ1(1 cylinder injector)_SC 11 1(L.F.)+1(S.F.)
ERROR_ INJ1(1cylinder injector)_SCG 12 1(L.F.)+2 (S.F.)
ERROR_ INJ1(1 cylinder injector)_OC 13 1(L.F.)+3 (S.F.)
ERROR_ INJ2(2 cylinder injector)_SC 14 1(L.F.) + 4(S.F.)
ERROR_ INJ2(2 cylinder injector)_SCG 15 1(L.F.) + 5(S.F.)
ERROR_ INJ2(2 cylinder injector)_OC 16 1(L.F.) + 6 (S.F.)
ERROR_ FANR (Fan Relay)_SC 23 2(L.F.) + 3 (S.F.)
ERROR_ FANR (Fan Relay)_OC 25 2(L.F.) + 5 (S.F.)
ERROR_ MA INR (Main Relay)_SC 26 2(L.F.) + 6(S.F.)
ERROR_ MA INR (Main Relay)_OC 28 2(L.F.) + 8(S.F.)
ERROR_ ENSTR (Auxiliary Starter Relay)_SC 29 2(L.F.) + 9 (S.F.)
ERROR_ D LAMP(Error indicator light)_SC 35 3(L.F.) + 5 (S.F.)
ERROR_ D LAMP(Error indicator light)_SCG 36 3(L.F.) + 6 (S.F.)
ERROR_ D LAMP(Error indicator light)_OC 37 3(L.F.) + 7 (S.F.)
ERROR_ LAMBDA 1(1 cylinder Oxygen Sensor) 47 4 (L.F.) + 7(S.F.)
ERROR_ LAMBDA 1(2 cylinder Oxygen Sensor) 48 4 (L.F.) + 8(S.F.)
ERROR_SAFETYSW(Roll-over sensor)0 49 4 (L.F.) + 9(S.F.)
ERROR_SAFETYSW( Roll-over sensor)1 50 5 (L.F.)
ERROR_ PK (Pick up)_OC 53 5(L.F.) + 3(S.F.)
ERROR_ PK (Pick up) 54 5(L.F.) + 4(S.F.)
ERROR_ IGN1(1 cylinder ignition coil)_CURRENT 55 5(L.F.)+ 5 (S.F.)
ERROR_ IGN1(2 cylinder ignition coil)_CURRENT 56 5(L.F.)+ 6 (S.F.)
Thank you Z,
Yes, this error is not on the table and it can't be deleted with the battery off reset. There aren't any dealers here either, closest must be 200 km away.
Maybe you're right it's a servicing reminder, it just started now that the bike is 6000 km. Do you mean you are getting the same?
It's service reminder.
Ignition off -> full throttle -> Ignition on -> Wait until EFI light turns on, then wait until it turns off -> Ignition off -> Release throttle..
