SUPERBYKE RMR 125 HELP REQUIRED
Hi All
I have recently purchased the above bike for my son and need some help with it if you can please.
1, Can the ignition timing be changed on these? If so, how and what is the setting?
2, the clocks aren't working, totally had it, speedo, miles, rev counter, totally blank. Any ideas? if i need new one's, where in the UK can i get them?
3, where can i get a good performance exhaust and new down pipe?
many thanks
john
Re: SUPERBYKE RMR 125 HELP REQUIRED
Dear John,
Greetings from Shanghai, and welcome to the forum! You're fortunate that there's quite a bit of information in mychinamoto about your bike, and it's pretty easy to find. Pull down the "advanced search" tab up in the right hand corner, and key in "SUPERBYKE RMR 125".
For your convenience, I've done this search and come up with many promising hits.
It seems that Superbyke RMR is one of many rebadgings of China's well-regarded Qingqi 125, so questions about the Qingqi as well as the Qlink, Pulse Adrenaline, TMEC and other variants likely will also apply to your bike.
Pictures of the bike, particularly with respect to specific wrenching and equipment questions, always help to stir enthusiasm and generate responses. Let us see your bike!
Do also let us know how you get on, and good luck!
cheers!
johnfitz1999
Hi All
many thanks
john
Old threads had answers :lol8:
1. 4 curves http://item.taobao.com/item.htm?id=9153886492 or Used parts (w/o rev limit & more aggressive curve) http://item.taobao.com/item.htm?id=9163911236
2. Maybe just simple things like cable F...s/ lossen connecter etc :naughty: cmpo.co.uk (Their price :eekers:) stocks most parts. There's always another option: ship directly from china via agent IF UK one ripoff ur wallet. :naughty:
3. Cheap "fleabay" (noisy) solution that ships from Thailand
here you go a good website to finding parts for a chinese bike
http://www.chinesemotorcyclepartsonl...kes_RMR125.php
superbyke is in bristol, you can contact them http://www.superbyke.co.uk/; if the do not have you can buy parts from the XF125 or QingQi 125 from ebay in the UK.
for #2 an alternate solution is using a cyclo computer. They're cheap and you can use them on more than one motorcycle/bicycle .. you just need to play around with the wheel size settings
Your speedo should be a machanical one running off the front wheel. The cable is weak and prone to breaking. It can be replaced with a Suzuki DR200 speedo cable. Get the newest year they have and it's a direct fit. Not sure why the tach isn't working. It's electrical. Do you have dash lights? The whole assembly can be gotten off Ebay if needed,http://www.ebay.co.uk/itm/Speedo-Spe...item2566d00aa5 ,but it sounds like a simple loose wire/ground problem.
