Pulse Adrenaline 125 Neutral Issue
Hi, i'm new to site and i have a Pulse Adrenaline 125 (2011), iv had it for just over a year now and it's developed a strange problem. The bike will only start in neutral, the problem is it will only start if the neutral light is on and even if the bike is in neutral the light won't always come on. Its a real ball ache when i get to a petrol station and the light won't flash and because the bike no longer starts in 1st with the clutch in, i have to bump it. It's a strange one but any advice would be appreciated, thanks.
Re: Pulse Adrenaline 125 Neutral Issue
most bikes will not start in gear if the side stand is down. Put side stand up clutch in and it will start in gear or if neutral light is off.
Check the switch on the clutch lever.
HI mate just like what the guy above has said, there is a wire with two lugs on the end. They plug in under the lever and the other end plugs in to the wire pack that is behind you headlight. It could be that one of the lugs have come loose and fell out. This will stop it from starting in gear. Thats it mate.
