Hi,
I recently replaced the super moto 17inch wheels on my qingqi with 18/21. Now the speedometer is way off.
Anyone had any luck adjusting it? Its a digital speedometer.
Hi,
Is there a model with that wheel size? Change the speed sensor?
Would assume speed sensor - check part numbers between the models
Basically each turn of the wheel shows a different length in distance blah blah
Your going slower then shown
Did you also change the gearing? Otherwise it will rev it's tits off
Update - found Taobao seller whom contacted the factory
It needs another speedo head
It seems the programming isn't adjustable externally
Assume it's in the chip etc something to do with software or the like
I was never able to find a Qing Qi speedo that could be adjusted, had to change the wheel sensor.
