Re: Lexmoto Adrenaline 125
THe good old carb version?
Stock backlight is incandescent light bulb & it will fail in the right moment. http://startright.co.uk/manuals/sinnis/apacheframe.pdf said 6* 12V 2W & cmpo.co.uk said it's a T5 1.7W. I tried this b4: Nail clipper & forcing those leftover T10 LED (V-shaped pattern as https://www.aliexpress.com/item/1Pc-...640299904.html works great ) into T5 https://www.per-accurate.com/catalog...&%20SOCKET.htm
Gear indicator. U can play it around using dummy load to verify the display is in OK condition It's just a https://en.wikipedia.org/wiki/Nine-segment_display. If it's engine side wiring problem. Leave just the "N" wiring & made some N indicator as old sckool bike... http://gd3.alicdn.com/imgextra/i3/67...!678135370.jpg Change the whole thing is PiTA
The wiring: http://pan.baidu.com/s/1b8M9cFBOKUHvUIW-lOpFqQ
