PULSE adrenaline 125 oil change
hi everyone, ive just undone my oil plug to drain oil ,and and spring and pin dropped out, i didnt see it just heard it, what way round do they go back in ? the pin is flat at one end and pointed at the other ,cheers i know sounds thick but im lost lol thanks
Re: PULSE adrenaline 125 oil change
That was the neutral finder plunger and spring, you don't need to remove that to change your oil, just the 17mm bolt at the bottom is all you need to remove. You need to insert the pin first with the widened end facing down then the spring then the bolt that holds it all in.
