Attachment 18685 Does anyone know what copy cat of the Japanese this engine is ? I wish to change the gearing . This bike is called a Cyclone and I bot the LAST ONE from Peace industry in Atlanta Ga USA
Based from CG125 http://world.honda.com/history/challenge/1975cg125/ Chinese fed steroid & got 150/175/200/250 ...
What's the model stamped on engine? 1??FM?
Compare the sprockets in jtsprockets.com. Most CG's front sprocket is JTF259. Some newer one is 5mm NOT 4mm
Thank you so much for the reply - I will check on this info you gave THANK YOU , Redcyclone
The Engine number stamped by the shifter is 167FMMDD followed by a ' STAR' , then there is a STICKER on the front of the engine which has this : 167FMMDD080081 thenon the left side of the swing arm is a plate with the name Chongqing Astronautic Bashan stamped on it .
The sprocket at the engine is a 15 tooth and at the rear wheel is a 35 tooth ,
Thanks againAttachment 18686Attachment 18687
167FMM = CG250
