Re: Maintenance On New Konker SM200 (Qingqi, Qlink)
spook
Here is the front end assembled again.
What I noticed when I first put the front wheel on out of the crate and when I put it on again today is that the wheel seems to not be centered. I measured each side and it seems that the wheel is about 5mm to the left (looking at this picture from the front). I looked at the wheel spacer and the speedo drive and brake caliper and everything is mount correctly. Any one else notice this on their Qingqi bikes? I have an '80's Honda that is off a little also, but it doesn't seem to affect anything. Just curious if this is common on different bikes.
Yep - when fiddling with my Loncin/CCM I noticed the new knobbly front tyre is close to the fork gaiter on the LH side but clears the RH side by about 1/4". Does seem to be a common thing - even my 2008 XTZ660 Tenere had the wheel offset to one side ...
Intention with the CCM is to turn up a new LH side wheel spacer say 1/8" longer than the original - the caliper self centres so this should sort the "issue" - will let you know how I get on . I suspect it is nothing more than a cosmetic problem but it bothers me every time I notice it !!
Got my daughter out riding a couple of times. Of course in the process she dropped the bike which is to be expected. I had not got around to putting any guards on the clutch and brake levers, so the front brake lever got broke. Looked through my spare parts and couldn't find anything that fit, so I took off the front brake lever from my KLR 650. Bolted right on! I ordered a new one from the local Kawasaki dealer and a few days later had it installed. So if you break a front brake lever of a Qingqi 200 a lever from a KLR will fit.
Good to know, thanks spook!
hey spook i also have purchased a konker sm 200, except i bought mine used with 5000 k on it. I am interested in buying off road tires for the bike and i noticed you have a back motocross tire on your bike. I am new to the world of motorcycles and i was hoping you could tell me the dementions, wheel size, brand, where to purchase them. Thanks again great pictures and posts!
Thread #26 and #30 gives the tire size. I cannot remember who I bought them from, but most online dealers will have something similar in size. They work well.
bojer
Just an assumption, since the bike has one brake disc and the caliper is braced to one side of the fork, could this offset be helpful in preventing side pull when braking ? I just had the idea but it's the only explanation I could think of since this happens in at least three different bikes (mentioned in the thread).
just my 2c
