just wanted to ask if what is the difference with this type of engines?..is there a difference in performance? which of these two engines are the one who is easy to maintain?..need some answers please..thanks!
The pushrod or OHV type will be easier to maintain, setting the valve clearance, removing cylinder head, etc.
In theory they have less performance but for a day to day ride to work you won't notice the difference.
If the systems are made well and ridden gently they should both be about equally as reliable. In a high performance environment I think the OHC (overhead cam with a timing chain) is better due to the circular movement of the chain and cam. When you start to rev a push rod engine real hard I think the up/down motion of the push-rods (which connect the crank with the valves actuators) can be a little rough on the engine especially since there's a change of bending the rods.
The plus side of a push rod engine is that as long as it's gently ridden, it's a real work horse. I've had one run for hundreds of kilometers after getting literally entirely flooded. OHC (cam chain) engine require a great amount of lubrication at the head or parts start to shred.
Just my .02
:riding:
