Shoul read 162 FMJ......i have been goggleing and think its a lifan. but more info would help alot.
These are the numbers on my motor( there are some others). I would like to know what is called so i can gain info to tune it.
I am trying to find a manual and what type of motor it is eg honda clone ? or something
It keeps blowing the fuse on the starter motor every time i rev it so i would like to fix it......seems a good motor .
12-31-2011, 01:08 PM
humanbeing
Re: 162 FML 150 motor
From ur description the machine uses 62mm piston which chinese called as CG150 . It's very similar to CG125 http://translate.google.com/translat...horid%3D290040
This site http://hondacg125.awardspace.com/ explained the basics. There's honda manual floating in net. Search "cg125" "storm" " service manual"
The common OHC clone uses 61mm:naughty:
01-01-2012, 12:36 AM
kikdbak
Thanks ...the laugin icon worries me..
from reading this seems to be a low performance but low maintence engine......hopefully i can get a bit more poke out of it.
That sound in the video seems like a drive chain that is loose? It does not seem like an internal engine sound.
I read the thread and it make really very little sense to me.
The engine offered in the US is rated at 9kw @9000rpm (12.25hp) not sure if it has ceramic cylinders though, SYM does use ceramic cylinders in newer engines. They advertise that technology for the scooters but I do not see it included on the information for the Wolf 150?
SYM is offering a 24 month warranty, the Wolf has has an EPA certificate for 2011, it was the change in distribution that delayed its arrival.
