hi , are the spark plug gaps on a cq150gy the same as a 125 settings 0.6 - 0.7 mm ?
If the plug is the same, then the gaps will likely also be similar. Is it using a Honda engine?
yes i am told its a honda clone , vertical 4-stroke .
Should be alright then, if it is indeed its the engine thats a Honda clone, and not just the body e.g. my Firebird looks like the Honda CM125 but the engine is based on a CG.
