took me ages to find this lol but here for all to view:clap::thumbsup:
http://cid-2115f0a88bd88f74.skydrive...ngshen%20110cc
110 chinese ATV engine is a 152FMH w/ reverse gear -the Genric parts inside
your right but they are both based on a honda c90 engine so most of the parts are the same i found the page you pointed me to before but they dont tell you how to fix things where as the c90 manual does it helped me fix my reverse gear and put it back together but yours it a good ref too thanks
man i am really in need of the of the specifacations for the wiring connectors that come off the zongshen 152FMH 110cc engine with 4 gear manual transmission with electric starter also
:wheelchair:HELP ME PLEASE
i have a zongchen motor off a 4 wheeler and need to wire it up and cant figure it out dont know what size it is but it is electric start and automatic shift 3speed w/reverse it has two wired plugs comming out of motor one has 5 wires (green/red-blu/red-red/white-green/blu-pink)the other has 4 wires(green-white-yellow-blu/white)then theres a black box it has 12 wires(orange-2yellow-red-blu-pink-gray-black)then a seperate black and 2white on a seperate plugcoil has 2wires black/yellow -green im putting this on a shifter cart since all the wires are missing on the 4 wheeler just have no idea how so if theres anyone that can help you can get me direct at george.virden@hotmail or post it herte i tryed to follow the diagrams youall have posted but nothing matching up please someone save me make the kids happy thanks to all
George, dude, you're from California! Take a deep breath. Chill.
Oh, and one more thing: Punctuate! Here's some little bits and bobs -- offered free of charge -- that might help make your message a bit more readable and increase the odds of someone taking the time to help: ,,,,,......!!!!!??????
Some pictures would help too.
Good luck!
i have a zongshen motor and have no idea what it is the only numbers are 108cm3 came off a atv and has 3 gears forward a reverce and is electric start im trying to wire it up on a shifter cart frame and cand find nothing on it thanks to all
k,ill keep that in mind, been an iron worker too long,grammer and spelling kindof fell to the wayside.Thanks and ill get pix up asap,im on the road now but ill get to it when i get home.Im not even sure if it is a 110 ,tryed to match pictures and it looked to be the closest
Zongshen diagrams in Chinese http://www.lnmoto.cn/bbs/thread-460165-1-1.html
Use translate.google.com for the correct "colors" in Chinese .
Recognize printed Hanzi isn't that hard , just think them as images
thanx toyou all this will help greatly
I have a 2011 Younghe 110cc go cart and in need of of a engine (crankcase) diagram, and cannot find one anywhere on the net. I will be replacing a thrust washer and drive bearing for reverse. Does anyone know where I can find one.
You say 110 cc? Horizontal cylinder and semiauto?
I do not know how it looks gearbox with the reverse in that engine, but I believe that every service manual for the Honda Super Cub will be helpful to you.
IT HAS REV!!! :clap: I just got one,I don't know sqwat :confused1: (MY $20 110cc 152fmh project). started my own diagram. Still a ways to go.
