Starting problem. Carb Blockage?
Hi.
I have a Pioneer XF200 and it will not start. The engine turns ok, and there is a spark but there is no petrol smell from the cylinder , so could this be a blockage in the carb?
I have already stribpped the carb and all jets appear to be clean, but there still seems to be no fuel getting further than the float chamber. Any suggestions would be welcome, Thanks.
Re: Starting problem. Carb Blockage?
Mikuni BS28 ? Something cracked http://item.taobao.com/item.htm?id=36180036512
Sundiro in past had some model powered by Kawasaki 175 LiNK
Those 175 uses "BS28" stock carb
http://www.motorfans.com.cn/bbs/view....php?tid=38917 | QM200-2V (June '05) in #28 is using Japan made carb
The diaphragm appears to be undamaged. I will strip the carb down again and check the diaphragm again and the jets for blockages.
Would I be able to replace this carb for a non-diaphragm type? There seems to be more of these available fairly cheap.
It seems to be much more serious. The timing is out because the flywheel has moved. The key strip (Which goes in the groove onb the crankshaft) has broken for some reason. Can these be replaced?
jimwelsh
... be able to replace this carb for a non-diaphragm type? There seems to be more of these available fairly cheap.
Guys @ http://chinariders.net/forumdisplay.php?f=104 had more experiece putting Mikuni slide carb on various chinese bike.
Jim the key is a woodruff key and you can replace it . You can lap the flywheel to the taper on the shaft with some valve grinding paste to get the two parts matching nicely . Then clean it well and fit the new key, tighten the retaining nut with some Loctite.
zhu
Jim the key is a woodruff key ... tighten the retaining nut with some Loctite.
Stock key is (3 x 13 mm) http://item.taobao.com/item.htm?id=12308468065 / Cheap as peanut in hardware supplier http://item.taobao.com/item.htm?id=37678037543 | Suzi service manual mentions HIGH tensile threadlocker (RED Loctite "27?" is similar) in that area.
http://www.motoyes.cn/bbs/forum.php?...ead&tid=126820
http://www.motorfans.com.cn/bbs/t_3214_14.htm
Hi.
Thanks for that. It's an exact match. I did look on cmpo.co.uk but there are none with the correct part number and they are £5.99. http://www.chinesemotorcyclepartsonl...e=woodruff+key
I will now send for the correct one from China. Many thanks.
Attachment 15981
K172FMM uses the SAME key
http://www.bikerswarehouse.co.za/spa...e%201.49mb.pdf
GB... is "chinese national standard". ANY parts listed w/ that means "std" item that can find via hardware supplier. http://www.keysandpins.com/products/woodruff-keys
I managed to fing a UK supplier for my Woodruff key. The nearest one that fits is for a Suzuki RM250. These are easily available on ebay:
Attachment 16270
