Lexmoto LSM 125 front sprocket
Hi guys
Im looking at changing the front sprocket on my Lexmoto LSM 125.
Ive not checked but I believe it is a 14 or 15 tooth front sprocket.
Im told if you put a sprocket on with more teeth you lose a bit of acceleration but you dont have to change gear as frequent and you get a bit more speed flat out.
Would it be best to go for the 16 or 17 tooth ?
Re: Lexmoto LSM 125 front sprocket
You are correct, your bike will be able to do the same speed as before at less RPM which will give you a few extra MPH on your top speed and give you better milage too. A 17 tooth would probably be a bit too much without any serious performance mods such as a 150cc big bore kit so it would be best to change to a 16 tooth and see how it goes.
You can get one from the link below for almost half the price of the one that llexeter is selling
http://www.ebay.co.uk/itm/PITBIKE-PI...item3f137422fd
You probably should read the measurment guide in the auction description to make sure that it is the right one.
How's the new sprocket treating you? Been considering doing this, but worried i'll loose too much acceleration. So, how much have you gained? worth doing? For 4.50 i'll probably get one either way though lol.
ta
Aaaaaaaand, how big a job is it replacing the sprocket? i can't see it being too bad, but i've not looked it the belly of the beast yet
