I know that the 200cc engine will just slide in to the sinnis apache. where can i get one and what a=do i have to do to make it run right
Hi
i think you need a complete head cylinder since it must have bigger valves and ports and then a new cylinder (199 cc) new big piston and rings and may be the crank shaft and timing chain
at least 30 mm carb (mikuni) is a must ...
and then check the exhaust collector size be sure that it fits the new head cylinder port if not try a new bigger header ...
No i cant just slap the 200cc engine parts in my 125 i need a whole new engine
Not sure where you are, but Ebay ususally has a good offering of engines, brand new. Not sure about the Sinnis which I believe is Qingqi-derived, which would make it essentially a Suzuki 200cc (these are usually different from the more common 200cc Chinese engines which are Honda derived).
Hi there im in the UK if you can find one for me as i have been looking on eBay for weeks and still cant find one. also what is the honda engine that will fit
I know this isn't a 200cc engine, but try the company since they are offering a 125cc engine http://www.ebay.co.uk/itm/NEW-GS-125...item1c17fcb9a4
Here's another 125 for the Pulse Adrenaline (which I believe is the same bike as the Sinnis), but they are sold by a breakers company, so might be able to find you a 200cc
the pulse adrenaline is built by another company and is 125 cc only its either sinnis route or a superbyke route for the 200cc engine
I forgot about 'Superbyke' I think there are three companies selling the Qingqi bike in the UK, although, like you pointed out Kennon, the Pulse is only available in 125cc form.
sinnis is also only in 125 altho plans to get the 250cc version over here. If i cant find the 200cc engine i will mod my 125 with a 150 bore and then save for a 250cc version
