Re: 2013 Dongfag 250 SXR Oil change?
It has the overhead cam Honda clone engine. CB250 clone?
This parts PDF might help
http://df-motor.com/MLC/Parts%20Menu-DF250RTC(2014).pdf
I'm pretty sure it has an oil drain bolt in the crankcase.
See
http://www.mychinamoto.com/forums/sh...hanging-of-oil
axa
id use that the term 'same' loosely... the dong fangs im nearly positive are Loncin made engines, at least for the 2012 year models, while ccw uses lifan i believe...
Is there a label on the engine type and its manufacturer just above the serial number, LF-something-something for "Lifan" and LC-something-something for "Loncin"?
Nice sensible looking motorcycle.
Heh, you are not visiting other topics. This one, branded as "Romet Ogar Caffe" is made by "Dafier", but there is also "Hanway", with the same design, but with "Yamaha" OHC engine, both from Jiangsu.
Zero
I've been away cause I just had a little boy Sat night, Eastern time.
Spent 3 days in the hospital
Well, that’s great! Congrats, papi!
And don’t stop there. Your kid will ned some some company for playing.
Zero
But when I do ride, she runs like a vibratory with fresh batteries
Thank you for sharing your personal experience with us. :lol8:
Zero
I'll keep updating you guys, one thing I know for sure, this bike is a needle in a hay stack to find any info.
If you're looking for a service manual for this particular bike, chances are that you’ll never find one. You'll find out about the engine from one source, about brakes from another source, on the sprockets from the third and so on. But have a doubt - you'll collect all the necessary info about the maintenance and repair very soon. As Axa wrote - they are simple, so have a little patience and you’ll get all you need. :riding:
Attachment 17081
Cannot for the life of me get this brake pad to close the pads.
're bleeding will not make a difference, nothing I've tried works.
Tried switching one of the two front calipers to the back, same issue.
Now no front brakes either lol.
Why won't these 're pressurize after 're bleeding using the blender screw?
axa
I didn't realize this was a CB engine clone, all my comments, while some still apply, were meant for the CG clone.
but even if you can find a model number on a label, that doesn't mean the replacement parts you find may fit all that well. that is my experience.
250RTC They evidently can have either?
Zero
Attachment 17081
You did something wrong, you may have to reverse that by connecting a line to the bleeder valve and pumping in fluid that way? I think you have air trapped in the caliber. If you cannot bleed that out through the bleeder valve, then you would need to feed the fluid in through the valve itself there are tools you can buy to do that.
I think the number one rule is to never allow that reservoir to go dry.
I had a bitch of a time bleeding the rear caliper one time on my DF. I ended up unbolting the the caliper off the bike, ( hose still on) hanging it down or up, I forget which , and using a Mityvac to get the air out.
axa
But in this case, I find it a little strange that the CB engine vibrates so much (remember - Zero is compared it with a vibrator). :eek2:
