Hey Bob from NV, where did you get your tank decals at?
AWESOME JOB DAN...thanks.
Them sprocket bolts are pricey..but less work than i had to do. Only question is what is the grade on them? not real importanty since the grade 8's I made mine out of last year,broke on me nayway..but I guess that is what they are supposed to do. Beats having to buy a new rear wheel cause the hub is mangled instead of the bolts breaking.
A friend of mine made them for me from a picture I found on the web.
I've just been tightening bolts and polishing lately, waiting for the safety class in mid May to get my endorsement.
:popcorn:
Attachment 11047Attachment 11048
i will take pictures when i take it off next couple of days. then post them with arrows 'n stuff
so anyway go to legendmcs.com then bottom of page to see tensioners. made by LBV. or any one of them that looks good to you. there are 3 or 4 of them. not cheap. then the tire will be too big to have enough play, or room, at least it was for me. so i found that spitfire skateboard tire. at 48mm its the smallest i could find.
i am sure there are other places and prices for chain tensioners.
so thats all i can walk ya'll thru rite now.
I have the monstercraftsman chain tensioner 1" clamp on. Had attached to rear frame cross tube by rear wheel, but the fit is a bit tight and when the chain goes tight the wheel is hitting the frame.
Everything was as it should be. The wires were tight as could be. Scooter depot says they are sending me an entire new tail light and if that doesnt work a new fender and mounts.. Idk..
Bike still is back firing through the carb and stalling when idle, but drives with no issues. Had a HELL of time changing the rear sprocket because the damn studs that hold the sprocket in kept spinning around and I had to jam a flat head screw driver in between the sprocket and hub to try and hold them still... BIG BIG pain in the butt. Instead of making a cover for the air injection removal im just going to plug the main hose and rip everything else off.. problem solved for 0 $.
http://i924.photobucket.com/albums/a...ps461e3be0.jpg
