Barnone I think you just hit paydirt for me. Lots of items I am looking for.. since I have over 25,560 miles on her.. need to update some stuff anyway. I will be calling asap.
http://parts.powersportsbest.com/ind...html?limit=all
Just so you guys know.I called them spoke to a wonderful Lady and they are in fact parts for this bike. I placed my order for the front shock assembly. I will let all of you know when they arrive. Thanks once again barnone, you the MAN.
25000 miles you must have changed your brake pads, with what?
there are indeed a few exact replacements on that site I've not seen anywhere else... or I haven't been looking...
I just buy these. They last a while, fit perfect and work well. no problems stopping.
http://www.ebay.com/itm/121235649136...%3AMEBIDX%3AIT
for both front and rear.
Great info.Thanks
Just got an email back and the pads are available here too. But your Ebay find is less since shipping is included.
https://www.partsroketa.com/df250rtb
bow. good info. I had the wheel off and couldn't get the shape of the pads.
I imagine front and rear are the same...
and if I recall correctly you changed your rear wheel cush drive rubber bearings... seems I broke a stud on one hole that was worn oblong...
have a link or part number? searching this forum is really hard
Yes both are the same. I have been buying different ones here and there some squeAK after a while drives me nuts. I guess it is just the material used. But they stop me just fine.
Also I am not at the house right now, but when I get back I will lok up the cush bearings and let you know. I know they were actually a Honda part number.
ok here is the picture I saved of the cush bushings
Attachment 19283
Thats the parts number for them. They still work great. Now I have broken one of the studs about a month ago, and replaced it. this is the part number for them
Attachment 19284
Hope this helps.
yep and pictures are worth 1000...
and if I might ask, are you sure these are genuine parts? I was under the impression that the genuine parts have a case hardened gray color.
the low quality Chinese made parts are this kind of yellowed zinc metal.
not that genuine parts can't break, I wouldn't know as I've been making my own but it's not like the 167fmm is a power house.
