heist222
So I need some information, hopefully Barnone or someone can help. I am installing new tail light and turn signals on this bike. Took it to a local bike repair place after I failed to wire them correctly. When I tried to wire them, nothing worked. I talked to the guy today and he said he has no idea, anyone have a wiring diagram or solutions for this? Do I need a new wiring harness? What am I doing wrong. Also looking for a new seat for this, I have a df-rtb-B
Member 'Humanbeing' seems to have a treasure trove of diagrams; if he does not chime in here, you could try PM'ing him :thumbsup:
heist222
This is the wiring diagram for the 2010 DF. Probably good for your B.
There should be one in your owner's manual.
Attachment 18950
I know this thread is almost 600 pages long--I am sure someone (probably you, Barnone) had posted the wiring diagram before! :clap:
As far as the seat goes, let me talk to my friend at Excalibur Motorsports; a couple weeks ago, the Dong Fang rep approached him to carry the DF products. My guess is the US operation is near Excalibur in So. Cal, so my friend should be able to find a seat for you.
You can call Alan at 909-591-8800 and ask if he can track down a seat for you.
www.atv4usa.com
Attachment 18952
Me on the Dragon. Last run there until I get back in April.
Love the picture of your restored 1918 Indian!! :riding::thumbsup:
culcune
Yep, I even fitted disk brakes fore and aft to add stopping power.
does anyone know of any common problems with the 2010 df250 rtb headlight I replaced the bulb and the daytime running light and that didn't help. so if there is a simple headlight assembly that is compatible with the stock mounts and simple to wire that would be helpful.:icon10:
Do you know how to use a volt ohm meter and read a wiring diagram? If so go back a few posts and look at the wiring diagram. You should be able to trouble shoot the problem. Just swapping out the headlight assemble is not the way to solve this problem.
This might give you some ideas as to how to supply enough full power to the head light shell and not through the dimmer switch.
H4 Kits
