Results 31 to 34 of 34
#31 Re: Changing fork oil on Qlink QingQi 200
- Aug 2012
- Long Island, NY
09-24-2012, 12:26 PMSorry to revive an old thread, but its the most useful info i have found on the subject so far. I see many talk of pvc spacers to increase preload, but no mention on which diameter pipe to use. Can someone please chime in? Thanks.
#32 Re: Changing fork oil on Qlink QingQi 200
09-24-2012, 01:05 PMPlease don't apologize for bumping an old thread. It's far preferable to starting a new one, which leaves information scattered hither and yon. This way all the discussion is in one thread where it can be most useful, as you've just discovered.
Unfortunately I can't answer your question, but there are plenty of people in MCM who can.
cheers!jkp
#33 Re: Changing fork oil on Qlink QingQi 200
- Oct 2013
- hong kong
#34 Re: Changing fork oil on Qlink QingQi 20012-15-2013, 02:26 AM
Well, it's been awhile since l've checked out this site. I sold the bike last summer after buying new in 2009. It was a great bike with few problems and fun to ride.
So, on to the question. Post #2, picture #2 shows the pipes that create pre-load. Putting a spacer between the top of the pipe and the clip will increase it. The concern here is to be sure the spacer is the same diameter as the pipe. Also, the spacer needs to be attached to the pipe as, unlike a coventional fork, the pipe doesn't fit snug inside the fork. The clip and the bushing at the bottom of the pipe center the assembly in fork. I think that wrapping the spacer and the top of the pipe with electrical or duct tape and then a band clamp would be ok. I would think that cutting away some of the top of the pipe would be a way to lower the front. You better be sure that you know how much you need, however as getting it back is a little hard.
QingQi 200 GY (Qlink, STx, et al) Repair Manual
By CrazyCarl in forum MaintenanceReplies: 29Last Post: 03-21-2015, 07:56 PM -
QingQi (Qlink) QM200GY About the clutch
By ChinaV in forum MaintenanceReplies: 19Last Post: 11-17-2012, 01:30 PM -
Exhaust can for Qingqi QM200GY (aka Qlink, etc)
By forchetto in forum MaintenanceReplies: 135Last Post: 06-22-2011, 01:46 PM -
QLink/QingQi 200 Sprockets and Parts
By C&K POWERSPORTS in forum Deals from DealersReplies: 3Last Post: 08-29-2009, 12:54 PM -
Price drop on QLink (QingQI) XF/XP 200
By chromedioxide in forum Dirt n' Dual-SportReplies: 16Last Post: 07-16-2009, 08:32 PM
