Results 1 to 2 of 2
#1 Starter reduction gear seizing on shaft. Please help. (Zongshen engine ZS177MM)
- Jan 2018
- Tuscaloosa, Alabama
11-26-2021, 08:47 AMMy bike is only a couple of months old and I am experiencing random starter issues. When starting the bike, most of the time the starter works. Occasionally the bike will attempt to start and then the electric starter locks up and will not turn the engine (Kick start still works). I can't get the starter to free itself.
I then have to remove the left engine cover and clutch assembly. This gives me access to to the reduction gear, the idler gear, and sprag gear. The reduction gear will be locked solid onto the shaft that is pressed into the engine case. A few times I have been able to take vise grips and twist is back and forth enough to free it. Two other times, I have had to heat the gear with a torch and then use the vise grips to twist it loose. Each time I have removed the gear, I have polished the shaft with 1000 grit sand paper and an emery cloth to remove any gauling on the shaft. I have also polished the inside of the gear. When I re-assemble, I apply a liberal amount of gear grease on the shaft and inside of the gear.
I have ordered and received a new reduction gear and shaft from CSC.
Having said all that, I have two questions.
1) What is causing this to happen?
2) I want to replace both the shaft and gear but I have no idea how to remove the old shaft from the case. How can I do this?
Thank you in advance for any help.
#2 Re: Starter reduction gear seizing on shaft. Please help. (Zongshen engine ZS177MM)11-28-2021, 12:14 AM
Hi fellow MCM inmate. While I can't offer specific Zongshen advice as such, I wonder is there any secondary gear possibly related to the reduction gear which in turn, turns an idler gear or some such?
That being said, if the bike is only a few months old, where's the dealer and warranty in all of this? Surely, you have consumer protections and warranty provisions that you can call upon in the circumstances?
You might be able to find specific advise on Chineriders.net where there are a larger cohort of owners and riders of Chinese centric brands 'stateside' in the lower 48, that might have a larger knowledge base.
Let us know how you get on and any progress made
Engine ZS177MM (nc250 4v)
By Robert Johnson in forum MaintenanceReplies: 0Last Post: 03-30-2014, 12:24 AM -
Zongshen 200cc engine questions
By Coloradogoose in forum MaintenanceReplies: 0Last Post: 03-03-2014, 05:33 AM -
Need help with Zongshen engine
By wolfmangk in forum ATV's/QuadsReplies: 5Last Post: 06-24-2010, 03:19 AM -
Zongshen CB250 ENGINE parts help
By Arcticmonster in forum Parts DeskReplies: 11Last Post: 08-19-2009, 03:41 PM -
Zongshen 240 (229?) engine - what do you know?
By Kawazacky in forum Dirt n' Dual-SportReplies: 7Last Post: 06-30-2008, 09:03 AM
комедии 2024 онлайн...
