Thread: Mikilon M96 Engine Mounts Broken
#1 Mikilon M96 Engine Mounts Broken
- Aug 2009
01-16-2010, 10:48 AMI fsee that the two lugs on the rear engine mounts are cracked and broken so will need to get the frame welded. Never been off-road or jumped speed humps or any other reason for this kind of damage on the frame. One suggestion is engine vibration.
Any ideas on the frame would be welcome. Is it likely a design fault? Do you think its worth getting welded or will it just break again?
#2 Re: Mikilon M96 Engine Mounts Broken01-18-2010, 04:21 AM
What I found is this can be a problem of inconsistent welding and/or sloppy assembly. Unless the frame itself is cracked, making a proper motor mount will probably be best in the long run.
Not exactly sure what your case would involve. Got pictures of the damage?
#3 Re: Mikilon M96 Engine Mounts Broken
- Aug 2009
01-22-2010, 12:51 PMThanks for the reply, I'll get some pics this weekend and post them here. The actual lugs are cracked on one side and the welding on the other has cracked.
mikilon m96
By andy375 in forum MaintenanceReplies: 16Last Post: 08-26-2014, 05:54 PM -
Mikilon m96 125SB 2008
By DJCW in forum Dirt n' Dual-SportReplies: 28Last Post: 08-26-2014, 05:43 PM -
Standard Air/Fuel mixture and Idle screw Settings for a Mikilon M96 125-SB
By da beard in forum MaintenanceReplies: 3Last Post: 10-23-2009, 06:42 PM -
Broken Stud in Gas Tank
By txm123 in forum MaintenanceReplies: 4Last Post: 07-11-2009, 01:18 PM -
Lost in Guangxi -The broken spoke diaries
By Supersignet in forum Ride Reports and MeetingsReplies: 24Last Post: 05-13-2008, 04:46 PM
