Thread: clutch problem
Results 1 to 10 of 20
#1 clutch problem
- Jan 2010
01-22-2010, 09:51 AMhi this is a bike i just brought i was told its a suzuko 200cc its a bit off a mess at mo some lad try to paint it by looks of it .
anyway im trying to put a new cluch cable on but i have no idea how it goes on its on at the lever but not near the engine
can some explan how this go,s on plz
also ive been told that this bike uses the same parts as the gy 125 200 and the kinrod bikes is this true all the plastics look the same on other bike pics ive looked at .
#2 Re: clutch problem01-23-2010, 06:51 AM
Chanley,
Usually the clutch cable at the end has a little metal barrel which needs to be fit into a notch on a long arm on the engine.
Whenever posting problems, it's best to to post pics if possible. If you're new to wrenching, using and understanding the correct terminology can be confusing and difficult.
Pictures say what we can't sometimes.
#3 Re: clutch problem01-23-2010, 02:43 PM
The barrel thingy CC refers to is shown left of the pic - the screwthread and nut is for adjusting the clutch. The other end has a nipple and you put it into the slot on the clutch lever on the handle bar. There will probably be a knurled round nut, which is used for fine adjustment of the free play on the lever - usually about 10mm to 20mm.
If this don't help, best to post pics.'09 Huoniao (Firebird) HN125-8 motorcycle [eBay bike-in-a-box]
Aprilia SR50 LC Racing scoot
#4 Re: clutch problem01-24-2010, 12:44 AM
Like this:
#5 Re: clutch problem
- Jan 2010
01-31-2010, 12:08 PMyes thxs i have a pic to show u so will any clutch cable do there is 1 on it now but i think theres bits missing P300110_12.480001.jpg
#6 Re: clutch problem
- Jan 2010
01-31-2010, 12:11 PMheres 2 more pics hope these help thxsP300110_12.480003.jpgP300110_12.480002.jpg
#7 Re: clutch problem
- Jan 2010
01-31-2010, 12:14 PMlooking at ur pics it looks like mine is at other side to urs mine is same side as kickstart not chain but this is where the wire was when i got it
#8 Re: clutch problem02-01-2010, 11:45 AM
That is a better place for the clutch cable, on my XF125GY, the cable comes in from the other side, and goes under the exhaust header, where the cable lube could be drying out due to the exhaust heat. What motor is this pic from, is it a modification on the old routing, or is it a modification available to existing owners ?
But as to the OP, there are emergency cabling kits available on ebay, a kit which comes with outer, a good length of inner and all the terminations that are used on most bikes. Just say you got the kit, about £18, found your ideal cable length and terminations, from that, you could get a cable made up, or make your own, with soldered on cable nipples.
http://shop.ebay.co.uk/i.html?_nkw=m...+kit&_osacat=0'07 Pioneer Pulse Adrenaline 125, ( XF 125 GY ) Suzuki clone ; K157 FMI engine
#9 Re: clutch problem02-01-2010, 12:02 PM
Hope these pics are self explanatory (should be able to see what you have missing)...
If you left click on the images they will come up bigger.'09 Huoniao (Firebird) HN125-8 motorcycle [eBay bike-in-a-box]
#10 Re: clutch problem
- Jan 2010
02-01-2010, 04:08 PMthem pics are great thxs i can see now whats missing so i know what i need do u know what the bit it called that the cable nipple is sat in at end as i dont have that bit but that is a massive help thxs
QingQi (Qlink) QM200GY About the clutch
By ChinaV in forum MaintenanceReplies: 19Last Post: 11-17-2012, 01:30 PM -
The Problem with Parts
By CrazyCarl in forum Parts DeskReplies: 1Last Post: 09-18-2010, 04:30 AM -
ZONGSHEN STORM 250 CLUTCH CABLE
By bmfwest in forum Parts DeskReplies: 8Last Post: 05-17-2009, 05:17 PM -
Clutch Noise
By Supersignet in forum MaintenanceReplies: 11Last Post: 05-30-2008, 09:30 AM -
Suter Slipper Clutch for CBR600RR 03-08
By ronny in forum Bike Market - ClassifiedsReplies: 0Last Post: 05-24-2008, 07:07 PM
