Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 SuMo with a Loncin 250cc engine
    C-Moto Not-so-Noob
    Oct 2009
    Portugal
    Hi guys!
    I'm thinking about getting this bike (the supermotard version) and I was wondering if you guys could help me figure out what brand is producing it outside of my country. In Portugal the brand is NMCompetition, but I can't find much info on these bikes.
    Does anyone know similar model with a different name?
    Here's a quick vid:
    http://www.youtube.com/watch?v=fVUGYt0exes
    Thanks!
  2. #2 Re: SuMo with a Loncin 250cc engine
    C-Moto Not-so-Noob
    Oct 2009
    Portugal
  3. #3 Re: SuMo with a Loncin 250cc engine
    Apr 2008
    NoVA
    OldBrotherMan,
    Looks like a Galaxy 250, here seen from Supersig's Falaxy factory tour
    It's also sold as SMC (Southern MotorCycle) in the UK.
  4. #4 Re: SuMo with a Loncin 250cc engine
    C-Moto Senior
    Jan 2010
    http://www.mikilon.com/index1.asp
    I get kick out of how they claim to be making products with conception.
    http://www.mikilon.com/about.asp
    They are offering six version of EEC motards….some look like a Loncin and with a 249cc and the others are 230cc.
    Call on them and ask…..I’ve been emailing question in Chinese and getting Chinese back and then translating. I get the impression that they appreciate that; me doing the work rather then forcing them to do all the translating.
    Doing translation require your computer to have Asian language support, you can install its dormant in windows, then all the wingding’s become Chinese symbols and Google translate will allow you to take them in the browser and instantly convert them to English.
    The groups are using a matrix system, they collectively manufacture. Its not high production today and sales lately are slow so most of the production should be from primary production lines. Is Mikilon an OEM of Galaxy?
    If a bike has a Loncin 250cc then all the peripherals of that engine are going to share supply lines; but some may do something a little different. They could be identical products but made in different locations.
    The nearly identicals coming from different locations could have different quality in the build and in after market support.
    In a matrix system often even the people in it do not fully understand it, so looking from the outside its not likely to see all the interrelationship. These types of systems have to rely on data and quantitative analysis then variances can be seen otherwise they cannot.
    call on them and ask.
  5. #5 Re: SuMo with a Loncin 250cc engine
    Apr 2008
    NoVA
    Going by their "about" page, it looks like the Mikilon in Europe is a direct branch of the the company in China and not an importer, like Qlink, PitsterPro or Krieger (?). I usually find importers try to hide or "conveniently not disclose" who the actual manufacturers are... and it makes sense.
    C
  6. #6 Re: SuMo with a Loncin 250cc engine
    C-Moto Senior
    Jan 2010
    Here is the English translation of the product.
    From the distributer site;
    The main objective of the company was to create a bike as an entry-level model with the best features possible, the level of performance vs reliability with a cyclist that can withstand the abuse of an amateur rider. Thus, they used a solid basis, which is equipped suspensions are robust and long-haul (Japanese), an engine 27CV cooled water with a very linear power, low maintenance, among other things that increased their performance and reliability, as a starter over-sized, a 30mm Keihin carburetor with PD model valve CFCA (Japanese) and the application of a double radiator the water. The company intends to young people in motorsport, and these models aprendisagem and evolution at a price hard to match. NMCompetition Models MX250, MX250 and SM250-R these are all models of initiation into the competition, of dimensions similar to a YAMAHA YZ250F, have a motor Loncin LC170FMM-2 of last generation 250cc 4-stroke with double-shaft balance and air valve, water-cooling radiator with dual read in conjunction with a 30mm Keihin carburetor PD model with an air cut valve CFCA (Acceleration Pump), an exhaust manifold and a 38mm tip income make this engine to charge the 21 Nm and 5600RPM 27CV the 7500RPM. The models also feature an inverted hydraulic front suspension fully adjustable in 48mm diameter and 300mm stroke, and behind a shock hydraulic diameter of 86mm and 85mm stroke, the chapter stop, they are equipped with disc brakes dual piston 270mm front and 240mm behind. The model SuperMoto goes to meet a new facet of the motorcycle market has been growing in recent times, that has all the features of the MX type, with a performance of some aluminum rims for supermoto 17 Polgar, lowering the center of gravity of the bike, getting this much more maneuverable, besides the application of a transmission slightly longer in this model. All models have electric starter provided with a battery powered by a Rotating the bike beyond the manual sitema kick to put the engine. In the field of security, the model is presented with a key system with steering column that cuts the power of the bike, making it impossible to connect in case of theft. Note: The power obtained from this 250cc engine was the primary aim of a linear track usage and strong, but always with the greatest reliability possible, existing engines from the same brand pulled over, but has a much more careful maintenance. This bike does not require a maintenance of a real motorcycle for competition level of the valves and piston, and only need to check to each use of the coolant level due to absence of reserve reservoir, the change of engine oil every 15 hours use, change the filters (air filter and oil) and verifying the proper operation of the suspensions. Both models come with a Certificate of comform EC and the European EEC certificate that allows the application for registration for use on public roads. Since these models of competition, their use in any terrain or on the public highway by the customer. The models do not have speed limit, and as all models of competition that their reliability 90% linked to the use and care that the driver of it. This way the driver should always have in mind the overheating of the engine, the level of coolant, oil level and the current state of the transmission, tires and brake operation. The legal circulation models for the public highway, require the installation of all accessories required by law. -------------------------------------------------- ------------------------------ Models MX250, MX250 and SM250-R are delivered with a Help Kit composed of: (a clutch lever, a brake lever, an air filter, fuel filter and a set of brake pads for front and tras) e used a post-sale service where innovative and delivered the bike with a CD-ROM with images of all pieces of the bike and the related code, where the customer only has to locate the component you want and send an email or contact the code indicating the unit, which in Portugal within 24 hours to get into his house, all with the aim of simplifying and instruct the client's operation and components of the bike, and to minimize the waiting time.
    DO YOU HAVE PRICES OF THESE?
  7. #7 Re: SuMo with a Loncin 250cc engine
    C-Moto Not-so-Noob
    Oct 2009
    Portugal
    Thanks everyone for the info!
    I'v already seen those NMCompetition bikes but the price is very high! 2650€ for the supermoto version (including lights), that's too much!
    All the prices can be seen on their site.
    I'll probably go buy something else, a used bike or so. Thanks!
  8. #8 Re: SuMo with a Loncin 250cc engine
    C-Moto Senior
    Jan 2010
    Yeah yeah…
    The Loncin engine 250cc and getting 27hp….that's maybe what’s going in the Megelli bike in the US?
    I would want a real good warranty on that engine! I wonder if the Yamaha WRX250 engine is made by Loncin? Yahmaha is asking nearly $7,000 for that bike in the US!
    Good example of brand recognition, BMW uses Loncin and I suspect so is Yamaha, but I could be wrong.
    Would the Yamaha customer go for the other brands? Are the BMW customers buying the Pisster pro 400 bikes?
    Odd they are totally different customers? They pay for the name, but they also pay for what comes with the name.
  9. #9 Re: SuMo with a Loncin 250cc engine
    C-Moto Senior
    Jan 2010
    That’s real nice that link also has the actual engines for sale and one of them for for just about $1,100.00 US... you can get this one…
    Loncin Engine 250cc 2009 model w / starter. In Preparation (Porting / head / Valves 32CV). Price only for customers NMCompetition.
    Price: € 800.00
    February 2009
    that does say 32hp right?
  10. #10 Re: SuMo with a Loncin 250cc engine
    C-Moto Senior
    Jan 2010
    This is great are you getting this, the engine can get 32hp but it won’t meet street legal but they are basically telling you and offering you all you need to get to 32 and also at your own responsibility.
    The thing is in the US if you offer modification or if modification exist then they are limited by the price the modification that exist. If a modification cost less then a certain amount and can be done relatively easily….then it isn’t going to meet the EPA requirements. That’s a fly in the ointment for that engine….and it could be why we is not seeing them here?
    Maybe?
    Round and round….
    Competition engines are not street legal and not durable for daily use.
    Does that explain some things like why other are not pushing the rates on that little engine and why the Yamaha has titanium valves?
    Posers and fried engines? Snap crackle pop! Your bike is smoking dude…thanks…no dude its really smoking!
  1. Our new SAGA 250cc L/C Scooter
    By SAGACanada in forum Scooter
    Last Post: 10-26-2010, 06:07 PM
  2. Replies: 32
    Last Post: 06-10-2009, 01:08 AM
  3. Shineray X2 250cc watercooled twincam 6speed
    By Supersignet in forum Dirt n' Dual-Sport
    Last Post: 04-11-2009, 04:54 PM
  4. Loncin engine clone of?
    By kingmarty45 in forum Street
    Last Post: 12-23-2008, 04:58 PM
  5. Shineray GY-7 with 250cc engine
    Last Post: 05-03-2008, 02:41 AM
