Results 11 to 14 of 14
#11 Re: re jetting, exhaust and cdi unit help
- Jul 2010
- Central, Ohio
08-09-2010, 10:26 PMLast edited by Moonbloodsflow; 08-10-2010 at 12:28 AM.
#12 Re: re jetting, exhaust and cdi unit help
- Jul 2010
- Central, Ohio
08-10-2010, 12:26 AMI have a clicking sound, that sounds like a relay, coming from the cylinder thing under the seat...wish I knew what it was but I'm a newb. Is this normal and I didn't notice it before or? It does a couple clicks when I start it up and and after I get done giving it some throttle, everytime.. Clicks 3-5 times like a relay or vacuum. I thought it might be the starter but theres nothing electrical connected to this thing? Is it something I could have done messing with the carb?
Even tho I still haven't adjusted the needle valve I went ahead and put everything back together. Bike seems to be running good, better throttle response and idles smoother. I changed both jets, spark plug and adjusted my fuel mixture. Exhaust should be here tomorrow at which point I will put it on and take off the SAI. If anyone can still help me with the needle valve that I seem to be blind to, I'd appreciate it.
#13 Re: re jetting, exhaust and cdi unit help08-10-2010, 12:54 AM
Don't worry about the needle. On your carb (same as mine) it's difficult to do and not much benifit. It involves removing the carb and tearing it down somewhat to move the needle. The other type of carb is easier to work on and moving the clip make more of a difference.
The thing in your picture is some sort of canister that is part of the fuel system. I had the same set up on mine but removed it when I took all of the SAI stuff off. Your tank is not vented through the cap like most bikes but rather through the canister by way of a check valve. You can see it in the lower right of your picture. The tube going off to the right is the vent for the tank. The check valve allows air to go into the tank but not anything out. When I took the SAI stuff off, I left the check valve and tube to the tank but took the canister and rest of the tubing off. I capped off everything that tubing went to exept the inlet to the check valve after the removal. If I remember right I had to cap three spots; the carb, the air box, and at the head where the SAI pipe was attached. If you do remove the canister, be aware that you have to be careful not to overfill the tank. It is possible for fuel to run down the tube to the check valve. With the canister on, any fuel that ran down would go into the canister and be sent back to the carb...at least that's what it looked like to me when I followed all of the tubing. Sorry this is so long winded but I was trying to figure out what I thought you would be asking. Hope this helps.
#14 Re: re jetting, exhaust and cdi unit help
- Jul 2010
- Central, Ohio
Performance CDI for Qingqi QM200GY (Qlink XF200, STX, etc)
By forchetto in forum Modifications (Cosmetic and Performance)Replies: 62Last Post: 05-30-2012, 06:58 PM -
Performance Coil and CDI
By stacyc72110 in forum Parts DeskReplies: 1Last Post: 07-07-2010, 06:43 PM -
s.o.s help to find a compatible cdi
By markm111273 in forum Parts DeskReplies: 7Last Post: 02-21-2010, 09:09 AM -
exhaust
By my_bloody_shineray in forum MaintenanceReplies: 0Last Post: 06-21-2009, 11:51 AM -
Need: Photos of kick start unit on XF200
By vladg in forum MaintenanceReplies: 8Last Post: 06-28-2008, 08:21 PM
