#1 Smoking wires when starting Kinlon 200SM
- Jun 2010
08-10-2010, 10:48 AMThought i was create a new thread rather then messing with my other on valves..
Anyhow.
While i had the tank etc off i noticed the wire from the back of ignition coul(green) was melted to exposed wire..I taped it up with insulation tape.
While using the electric start i then noticed it did the same thing on a wire from the the negative terminal battery terminal as it was melting/smoking.
Could this be a bad earth or something?Dont really want to cook my wiring and have to kickstart
#2 Re: Smoking wires when starting Kinlon 200SM
- Nov 2009
08-10-2010, 12:39 PMCheck the large negative battery cable that goes from the battery to the engine case. If it's disconnected or has a bad connection the starter motor current will be carried by whatever smaller ground is available.
#3 Re: Smoking wires when starting Kinlon 200SM
- Jun 2010
08-11-2010, 07:56 AMthanks..I will check that as i had that off to put some tidy up sleeving on it.
#4 Re: Smoking wires when starting Kinlon 200SM
- New Zealand
01-28-2012, 09:02 PMMost chinese bikes use wire that is way too thin, especially battery leads. I would replace both battery leads with a heavier wire, I have seen hundreds of them that smoke the original wires under load.
kinlon update
By stromnes in forum Modifications (Cosmetic and Performance)Replies: 19Last Post: 07-21-2011, 07:19 AM -
KINLON what is happening?
By jape in forum Industry News and Moto TalkReplies: 13Last Post: 05-21-2010, 12:13 AM -
Kinlon 200sm Battery problem
By marius in forum Dirt n' Dual-SportReplies: 5Last Post: 05-15-2010, 05:22 AM -
Mechanical help needed - poor starting and running
By casper in forum MaintenanceReplies: 3Last Post: 01-07-2010, 04:00 PM -
Smoking
By david3921 in forum MaintenanceReplies: 3Last Post: 04-19-2009, 10:39 AM
Get vivid impressions and...
Yesterday, 11:58 AM in Off Topic Discussions
