#1 Pulse Adrenaline Chain and Sprocket
- Dec 2010
- Dublin
01-24-2011, 11:12 PMHi guys,
Will the following fit the XF125GY - Pulse Adrenaline?
It's a chain and sprocket from a Suzuki DR100 - This is the link http://cgi.ebay.com/ebaymotors/Suzuk...item1c17b8e00d
If not can someone please send me a link to where i can get chain and sprockets without spending the earth
Anyone know the best sprocket size for going arond town with some open road driving?
#2 Re: Pulse Adrenaline Chain and Sprocket01-25-2011, 03:23 AM
Front: JTF426
DRUM version Rear: http://www.mychinamoto.com/forums/sh...ll=1#post17021
Chain: Re-calcaulate by ur self if changed sprocket. Default is 13? Links. Taiwanese brand Triple-S / KMC heavy duty type are enough for on-road use.
#3 Re: Pulse Adrenaline Chain and Sprocket01-28-2011, 11:35 AM
How did you go with this? Let us know. I also found an old thread with a lot of info.
See post 6 for the link here http://www.mychinamoto.com/forums/sh...0611#post20611Kinlon R/T KBR JL200GY-2
#4 Re: Pulse Adrenaline Chain and Sprocket
- Dec 2010
- Dublin
01-30-2011, 09:10 PMGreat, was going to try 16 tooth on front and 38tooth on rear. will it work?
#5 Re: Pulse Adrenaline Chain and Sprocket01-30-2011, 10:03 PM
I think that ratio is coming down too low at 2.375:1.
You should do one or the other I reckon.
No-one else here is helping anyone much lately but I am not the most experienced in these things by a long way. I read somewhere that it is best from 2.75 to 3.25 and that that really depends on the internal gear ratios but is a safe enough range to work within! You need a mechanical engineer or someone more experienced than me to explain this stuff properly. I have done this on my bike recently and more decades ago, but I am not a mechanic.
The front change alone should help a lot. What are the sprockets you have at present? If you have a 13 tooth front and 44 rear (ratio 3,3) - then just the rear down to 38 will give you less low-end and higher top-end at 2.9 and be quite comfortable for the engine to handle . Or if the rear is say 44 then going to 16 front alone will do the same approx. at 2.75 but may be flatter in the low gears which shouldn't be a problem unless you are hill-climbing in the mud or something.Kinlon R/T KBR JL200GY-2
Pulse Adrenaline
By Rodders in forum Dirt n' Dual-SportReplies: 24Last Post: 02-01-2011, 04:47 PM -
pulse 125 front sprocket
By sammy in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 10-28-2010, 01:50 AM -
Nearly Done; Pulse Adrenaline
By Sprocket in forum Dirt n' Dual-SportReplies: 14Last Post: 10-19-2010, 11:22 AM -
rear sprocket needeed for adrenaline pulse.
By Dan in forum Parts DeskReplies: 9Last Post: 10-05-2010, 08:21 AM -
Chain and Sprocket Set Pioneer XF200-2V
By jimwelsh in forum Parts DeskReplies: 9Last Post: 09-22-2010, 12:02 AM
