Thread: RMR 125 starting problem.......
#1 RMR 125 starting problem.......
- uk
09-28-2011, 08:35 PMHi, My sons 125 was having a flat spot just above idle and had been having issues with water getting in the electrics so we decided to check the bike over. We cleaned some dodgy contacts and the electrical issues appeared to go away. However the misfire above idle didn't go away. The bike would start but as soon as you tried to rev the engine, it died. The bikes only done 3000miles. We checked the carb for dirt and it seemed fine. We blew out all teh jets (its a simple piston based carb). We cleaned the fuel filter in the tank. Now the bike wont start. We get fuel to the cylinder and spark at the plug. We have changed the coil (+ lead and cap), changed the spark plug and still the bike wont start. We have charged the battery. It spins ok but wont fire.
Given our electrical problems, could something else be bu**ered?
All suggestions welcomed....
#2 Re: RMR 125 starting problem.......09-29-2011, 02:15 AM
mystery black box (CDI) F***ed OR the "occasional" http://translate.google.com/translat...082%26page%3D1
#3 Re: RMR 125 starting problem.......
- uk
09-29-2011, 06:21 AMCheers mate, will give it a try.
#4 Re: RMR 125 starting problem.......09-29-2011, 07:30 AM
Also checks valve clearence
Good Reference material: http://www.4shared.com/document/gZNL...uki_Yes_e.html Although it's in Brazilian Portuguese BUT the "infos" are clear
#5 Re: RMR 125 starting problem.......
- uk
09-29-2011, 05:39 PMMy portuguese is a little rusty !
#6 Re: RMR 125 starting problem.......
Smoking wires when starting Kinlon 200SM
By halfcasted in forum MaintenanceReplies: 3Last Post: 01-28-2012, 09:02 PM -
SUPERBYKE RMR 125 - STARTING ISSUES
By s91s91 in forum MaintenanceReplies: 2Last Post: 12-05-2011, 10:46 AM -
By s91s91 in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 10-05-2011, 05:23 PM -
My Qingqi QM200GY not starting
By tebete in forum MaintenanceReplies: 2Last Post: 08-29-2011, 07:37 AM -
Help with intermittent starting on Motorbike
By wolverine in forum MaintenanceReplies: 8Last Post: 06-17-2011, 10:17 PM
