Results 21 to 30 of 72
#21 Re: TDC at compression stroke
#22 Re: TDC at compression stroke01-27-2011, 05:39 PMAsk me nothing - I DO NOT speak english. Really...
#23 Re: TDC at compression stroke01-27-2011, 10:42 PM
If this is as stated, it just means he finally understood the joke and edited the cursing out before you saw the post on forum? Let us hope so, that is going a bit far, even for me and I don't mind the odd stoush.
Kinlon R/T KBR JL200GY-2
#24 Re: TDC at compression stroke01-28-2011, 07:13 AM
Jape, no big deal.
#25 Re: TDC at compression stroke09-30-2011, 03:57 PM
Hi,
soon i will adjust valves of my QM200GY. They are little noisy when engine warm, no performance problems, pulls like a train.
I recently bought her as second owner, now 6200 km on the clock and i am afraid valves never been checked...
I owned many big CC bikes before and exhaust valve gap was always LARGER than inlet valve gap.
Are you REALLY SURE both exhaust and inlet valves have to be adjusted at same measurement, 0.07mm for QM200GY ?...
Sorry for beeing suspicious, just want to be 100% sure..
Thanks..Yes, Basri is my name and avatar is real me...
#26 Re: TDC at compression stroke09-30-2011, 06:26 PM
Hi
it was noted in dr200 SE service manual that both inlet and exhaust must be the same and in range of 0.08 to 0.13 so i put mine on 0.10 and works fine no click sound .....
#27 Re: TDC at compression stroke
#28 Correct valve clearance for QM200GY...10-02-2011, 05:42 PM
I do not want to do this unpleasant job twice, please somebody advice me the correct (best performing) clearances.
This ?...
Or this ?...
Or, should i take an average measurement, 0.07 + 0.10 = 0.17 ÷ 2 = 0.085 ?..
Or, it is not such a big deal, just don't let them set too tight and keep rolling..?
Thanks,..Last edited by Basri; 10-02-2011 at 06:08 PM.
#29 Re: QingQi (Qlink) 200GY Illustrated Valve Adjustment10-02-2011, 06:16 PMin range of 0.08 to 0.13同志仍需努力
#30 Re: QingQi (Qlink) 200GY Illustrated Valve Adjustment
