Thread: Gearbox problem?
Results 1 to 3 of 3
#1 Gearbox problem?
- May 2010
05-03-2012, 06:04 PMHi!
Well today a new problem appeared in my Kinroad xt125gy. When switching from 2nd gear to 3rd gear about 50% of times it... just stays in 2nd gear.. what an obnoxious feeling. Then I switch one more time and it switches.
Can you tell something about that? Where is the problem and how can I fix it? And how expensive it will be..?
#2 Re: Gearbox problem?
#3 Re: Gearbox problem?
- May 2010
05-06-2012, 09:14 PMYes, I adjusted the clutch cable (Should have been tightened before, what a fail)
BUT it did not solve the problem.
I noticed, that if I release the clutch very slowly, the switching from 2nd to 3rd gear is OK, but if I release the clutch fast (like normally) then in most cases it has jumped in 2nd gear..
Additional information: the run of the motorcycle is about 5000km, regular oil changes and that is not the first time I use clutch :DLast edited by Valts; 05-06-2012 at 09:16 PM. Reason: grammar mistakes
Fuel Tap problem? Maybe
By vinidi in forum Parts DeskReplies: 2Last Post: 02-19-2012, 03:52 AM -
starting problem
By 1callum in forum MaintenanceReplies: 0Last Post: 11-17-2011, 08:23 PM -
The Problem with Parts
By CrazyCarl in forum Parts DeskReplies: 1Last Post: 09-18-2010, 04:30 AM -
car problem ...help!
By jape in forum Off Topic DiscussionsReplies: 7Last Post: 05-26-2010, 12:56 PM -
Gearbox again - SBS125
By Phil007 in forum MaintenanceReplies: 3Last Post: 03-31-2009, 07:13 PM
комедии 2024 русские
04-29-2024, 07:03 AM in Off Topic Discussions
