Results 11 to 11 of 11
#11 Re: Pioneer (Qingqi) XF200 Starting Problem08-04-2012, 10:06 AM
The starter and the drive are always in contact, its the starter clutch that separates them. That and Neutral separates them, the later from the gear train, rolling the bike backwards while in gear is not advised even while the clutch is pulled, the clutch does not disengage this always in contact scenario that is one way. I believe that is the case because the starter is on the primary drive gear that is on the other side of the drive clutch. So even if the bike has its clutch pulled the contact to the starter gear is still there.
So starting the bike and then putting it in gear and with the clutch pulled and then rolling backwards is putting the area of contact in a direction it is not supposed to go…backwards and if the starter clutch is not fully retracted it could have caused the problem, it may have caused the issue.
Starting Problem Pioneer XF200-2V
By jimwelsh in forum MaintenanceReplies: 0Last Post: 02-25-2012, 03:09 AM -
starting problem
By 1callum in forum MaintenanceReplies: 0Last Post: 11-17-2011, 08:23 PM -
RMR 125 starting problem.......
By s91s91 in forum MaintenanceReplies: 5Last Post: 09-29-2011, 10:49 PM -
My Qingqi QM200GY not starting
By tebete in forum MaintenanceReplies: 2Last Post: 08-29-2011, 07:37 AM -
Chain and Sprocket Set Pioneer XF200-2V
By jimwelsh in forum Parts DeskReplies: 9Last Post: 09-22-2010, 12:02 AM
комедии 2024 руÑÑкие
Yesterday, 07:03 AM in Off Topic Discussions
