Results 1 to 10 of 22
#1 110cc 152fmh ya another spark question
- Aug 2012
- michigan
08-05-2012, 09:16 AMI just picked up a 110cc 152fmh and it has no spark, but I know what your going to say "ignition coil " I have ordered one it will be here in a few days and can't wait. My question is how can I test other components while I wait on my coil. Stator, source coil, cdi, and rectifier. I believe that the cdi is ok used multimeter on it but not sure i know what i'm looking at. I will post pics soon to better explain. thanks
#2 Re: 110cc 152fmh ya another spark question08-05-2012, 10:57 AM
Do some carb clenaning, valve adjustment, cleaning and lubricating chain, while you wait. In any case, these jobs would be waiting for you after coil installing.
#3 Re: 110cc 152fmh ya another spark question08-05-2012, 11:00 AM
Spec from CDI maker: http://www.sanxin.com.cn/info5/index.asp?id=12
Other parts can use http://www.dansmc.com/electricaltesting.htm as a general guidance.
#4 Re: 110cc 152fmh ya another spark question
- Aug 2012
- michigan
08-06-2012, 03:03 AMCarb is already soaking, going to do oil change and chain tomarrow. BUT I think the coil isn't the problem!!!!! I checked the ignition coil with multimeter and I think it is good.
I opened stator cover and water came out.
#5 Re: 110cc 152fmh ya another spark question
- Aug 2012
- michigan
08-06-2012, 03:29 AMSo I polished out the rust, and thie pick up spots then checked with multimeter;
100_1511.jpg100_1513.jpg rust
The only one I didn't get a reading on the part i think is called the exciter coil.
Is this part bad? Sorry first time using multimeter. I also checked blue/white wire to CDI for breaks it was ok.
#6 Re: 110cc 152fmh ya another spark question08-06-2012, 03:58 AM
It's the older type!!! the newer one (http://s.taobao.com/search?q=%8F%9D%...obaoz_20120806) is compatible with GY6
Direct swap: http://item.taobao.com/item.htm?id=10836206479 fleabay is ~$19.99
Upgrades for the older type.
ALL DC (ie. no source coil) -DC CDI needed http://item.taobao.com/item.htm?id=4435967033
The 90W 3+1 http://item.taobao.com/item.htm?id=14804910536Last edited by humanbeing; 08-06-2012 at 05:19 AM.
#7 Re: 110cc 152fmh ya another spark question08-06-2012, 01:12 PM
A man can always learn something new. This is the first time I saw 3+1 coil for horizontal engines.
Thanks, Humanbeing!Ask me nothing - I DO NOT speak english. Really...
#8 Re: 110cc 152fmh ya another spark question08-06-2012, 01:25 PM
Not to forget: according to the manual I have for horizontal engines, the primary coil resistance should be between 0,1 to 1 Ohm, and the secondary, with the spark plug cap - 7000-9000 ohm, and without spark plug cap - 3000-4000 ohm.
So Arlie, if manual deceived me, I deceived you.Ask me nothing - I DO NOT speak english. Really...
#9 Re: 110cc 152fmh ya another spark question08-06-2012, 02:38 PM
One of the maker's specs: http://www.sanxin.com.cn/info5/index.asp?id=20
China always had those strange gadget
Diy 6V to 12V (ALL DC) http://www.motorfans.com.cn/bbs/t_86356.htm
#10 Re: 110cc 152fmh ya another spark question
- Aug 2012
- michigan
08-07-2012, 04:44 AMThe odd things seem to find me.:l
ol8:
110cc extra wires. gear indicator???
By arlie1180 in forum Parts DeskReplies: 6Last Post: 08-03-2015, 06:41 AM -
My $20 110cc 152FMH project
By arlie1180 in forum Parts DeskReplies: 3Last Post: 08-16-2013, 03:55 PM -
c90 engine diagrams just like zongshen 110cc
By jmcdonald151 in forum ATV's/QuadsReplies: 12Last Post: 08-03-2012, 08:27 AM -
By arlie1180 in forum Parts DeskReplies: 0Last Post: 08-03-2012, 08:06 AM -
Lifan GY-3 110cc trail bike
By doctorforgolf in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 10-31-2010, 08:21 PM
